Problems after EGR Delete
I attempted to do the EGR Delete myself and save some money but it did not workd out too well for me. I installed a Sinister Delete. When taking out the manifold I broke the electrical cap to one of my injectors at the base. I believe I am going to have to replace the injector because I have not seen the plastic electrical connector for sale by itself. I was not having any problems with my truck, just decided to delete before I started having problems. With the electrical connector attached the best that it could be I run my truck. It runs very bad at first like it is running on 6 cylinders. After it warms up it runs better.
I noticed that when I push the truck the turbo boost gauge does not go past the half mark (20lbs). With the truck running I tried to adjust the injector cap that was busted to see if it would run better but it did not. With the truck running I disconected the electriclal connector to see if there would be a differece in the way the truck ran and I noted it ran worse when I pulled it so I dont know if that is my problem or not. Any suggestions?
