4wd wont engage - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-02-2010, 12:16 PM Thread Starter
Another 6Slow
bouboy02's Avatar
Exclamation 4wd wont engage
My truck decided to get stuck and when I went to put it in 4wd the light came on but it wouldn't lock in no matter what I did so I had to have a buddy drive 45 min to drag me out I thinks it something simple its never made any bad clunks goin in or out of 4wd is their an actuator that coulda went out or something like that. thanks mike
2007 F-350 Motor built by Hostile Diesel, Transmission built by River City Diesel, Compounds built by Cutting-Edge Diesel
bouboy02 is offline
post #2 of 8 Old 11-02-2010, 12:29 PM
Unapologetically American
2006PSDSD's Avatar
Quoted: 27 Post(s)
Feedback Score: 4 reviews
Did you ever try to manually lock your hubs?
Sounds like a vac leak, or maybe the PE switch for the front hubs
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 8 Old 11-02-2010, 01:34 PM Thread Starter
Another 6Slow
bouboy02's Avatar
Yea I manually locked the hubs and tryed 4 low and I didn't do anything
bouboy02 is offline
post #4 of 8 Old 11-02-2010, 01:42 PM
2006PSDSD's Avatar
Quoted: 27 Post(s)
Has to be the actuator on the t-case then, IMO
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #5 of 8 Old 11-02-2010, 04:32 PM Thread Starter
Another 6Slow
bouboy02's Avatar
ill have to check it out thanks for the help
bouboy02 is offline
post #6 of 8 Old 11-02-2010, 04:41 PM
2006PSDSD's Avatar
Quoted: 27 Post(s)
No problem!
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #7 of 8 Old 11-02-2010, 04:42 PM
if you remove the 3 bolts holding the transfer case motor to the transfer case, then grab a 9/16 wrench and turn the shaft coming out of the transfer case(one click 4hi 2 4lo) You can manually do this. Its a pain. Once you do this you should no longer be ablt to spin the front drive shaft by hand. Its engaged to the transmission now, via the chain in the case. If you do this and drive it in 4 hi, you will know that the tc is good and its the 150 dollar motor that went bad. If you cant switch it manually into 4wd(still does not work) its the transfer case bad or both.
2008 6.4 f250 lariat 4wd
melmount is offline
post #8 of 8 Old 11-02-2010, 06:24 PM Thread Starter
Another 6Slow
bouboy02's Avatar
im hoping for the actuator but if that doesnt fix it ill check the t-case out thanks for help never thought of doing that
bouboy02 is offline
