Edge Insight w/ Dash Pod Installed - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-31-2010, 05:17 PM Thread Starter
mah77's Avatar
Finally finished the install.
After a 45 minute drive, here are my results:
Outside air temp was 65*. Mostly level stretch of road. Maintained 65 mph. Nothing in tow.
EOT = 195.3*
ECT = 189*
EGT = 869*
TFT = 144.8*
06 F250 FX4 Lariat, 35" Nitto Terra Grapplers, 6" Lift Leveled w/Bilsteins, 4" MBRP TB Exhaust w/Cat Delete, Edge Insight w/EGT Probe & Dash Pod, SCT X3 w/SRL Tune From Matt @ Gearhead, Powerslot Rotors, Hawk Pads, Upgraded Oil Cooler Screen, Upgraded Turbo Drain Tube, Upgraded STC Fitting, Upgraded FPR Spring, CAT ELC Coolant, ARP Head Studs, Opti-Lube XPD, Coolant Filter, 45K Miles
mah77 is offline
post #2 of 17 Old 10-31-2010, 05:21 PM
majorleaguebass's Avatar
how is the pod??? can u see everything well?
2015 F350 Platinum
TK Performance
4" Rancho w/ Fox Shocks
24" American Force Independence
37" Toyo Mt
Custom Bullydog Cheats
5" Flo-Pro
H&S Intercooler Upgraded Pipe
majorleaguebass is offline
post #3 of 17 Old 10-31-2010, 05:34 PM Thread Starter
mah77's Avatar
Fairly well. I had to play around with the brightness and contrast a little bit. Still deciding on a background color.
The pod is a good fit, but not perfect. I like the more factory look of the pod, but wish it were more in front of me.
mah77 is offline
post #4 of 17 Old 10-31-2010, 05:39 PM
how did ur upfitter switch install go?
2015 F350 Platinum
TK Performance
37" Toyo Mt
5" Flo-Pro
post #5 of 17 Old 10-31-2010, 05:53 PM Thread Starter
mah77's Avatar
Fairly easy. I have AUX4 switching the high idle mod and the AUX2 switching my rear driving lights. I'm probably gonna use AUX1 for my front driving lights (taken off the headlight rotary switch), and AUX3 for the defrost on the side view mirrors (I hate that they're on all the time).
mah77 is offline
post #6 of 17 Old 10-31-2010, 06:04 PM
iam trying to get that for christmas...along with some other goodies
2015 F350 Platinum
TK Performance
37" Toyo Mt
5" Flo-Pro
post #7 of 17 Old 10-31-2010, 06:20 PM
Galaxie's Avatar
Looks great! This is my next mod...this or a new CD player and speakers.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #8 of 17 Old 10-31-2010, 06:32 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
That way at least you can listen to good tunes while you're sitting in the driveway wishing you could drive it.
RIP Mitch
the Org crew
PGreenSVT is offline
post #9 of 17 Old 10-31-2010, 06:39 PM
PGreenSVT's Avatar
Looks great man. Good on you.
RIP Mitch
the Org crew
post #10 of 17 Old 10-31-2010, 10:24 PM
Good job, looks good now you need a fuel pressure gauge and with the upfitter switch you can use the number 4 to power it and 3 for the light works great mine is a column mount
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
