Sweet Jesus !!!!! - Ford Powerstroke Diesel Forum
post #1 of 31 Old 10-31-2010, 04:06 PM Thread Starter
Sweet Jesus !!!!!
I have been on your site for 30 minutes and I'm driving a piece of junk!!!!!! Ok here is where I stand.
Stock motor and 62000 miles
Been keeping up with oil changes
Just put on a AFE prostage 2 air filter
3.5" down with a 5" back MBRP Exhaust
Now thinking about trying to save what is left of my truck. What should I focus on next?
So what is next a coolant filter and change out the orginal coolant?
Also thinking about some kind of better primary fuel filter system or just easyer to change.
I also see you guys going on about readings are you getting them from chip upgrade data or adding extra instruments?
Thank for the inout that i'm about to get!!!
NEWBIE
speops38 is offline
post #2 of 31 Old 10-31-2010, 04:09 PM
Galaxie's Avatar
No! There are a lot of 6.0s out there and our trucks are expensive. When somthing goes wrong we freakout. All motors have their issues. I just wish we didnt have head bolts or EGR Valves! lol
Good truck man!
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #3 of 31 Old 10-31-2010, 04:11 PM
jesilvas's Avatar
Quoted: 2 Post(s)
62k and it's a piece of junk?
I'd say coolant filter and flush it out too. The fuel filtration on these is usually pretty good so I wouldn't worry about that.
A lot of guys add an Edge Insight I think it is. From what I know, it plugs into the OBD port and just uses factory sensors.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 31 Old 10-31-2010, 04:20 PM
welcome to the org man! you need to run an oasis report to see what you are working with and look into egr delete head studs programmer etc...
Originally Posted by azkcr View Post
That is unless Chuck Norris finds you first, then round-house kicks you to the face for not going to google and typing "stacking 6.0 powerstroke".
It has nothing to do with "power gains".. Your truck will literally just suck.. Literally suck..
TNStroKE is offline
post #5 of 31 Old 10-31-2010, 04:21 PM
f350powerstroke's Avatar
flush the coolant and add the bypass coolant filter. an be on top of the fuel filters. stay with the stock air filter.
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
post #6 of 31 Old 10-31-2010, 04:26 PM
make sure you buy motor craft filters
TNStroKE is offline
post #7 of 31 Old 10-31-2010, 04:29 PM Thread Starter
What is a oasis report? I didn't really panic or think it was junk but was wondering if in the morning it was going to be sitting in the drive leaking most of it fluids. On coolant filter and coolant which one? who's is best too use? Same on egr/ head bolts. Seen some in the last diesel mags. Bulletproof and others which are best for the buck?
speops38 is offline
post #8 of 31 Old 10-31-2010, 04:38 PM Thread Starter
It figured it out!!!! Thanks will try to up date my stuff shortly!!
speops38 is offline
post #9 of 31 Old 10-31-2010, 04:47 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Dieselsite is usually the consensus for the filter kit. I've built my own and it only came out maybe 25 bucks cheaper.
Coolant, use some ELC red coolant. I just used a generic brand, but most use Cat ELC.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 31 Old 10-31-2010, 05:01 PM
Superduty123's Avatar
You wasted your money on both the two stage air filter and the 5" exhaust
The stock air filter system on the 6.0L is the best on the market. Unless your making over 500HP you don't need anything bigger than a 4" Exhaust.
Superduty123 is offline
