smoke from hood???-help - Ford Powerstroke Diesel Forum
Old 10-31-2010, 10:55 AM
Ok when i have the sct on performance (canned tune) and i get on it smoke comes out from under the hood just on the driver side tho and i can see the soot build up on my egt probe wire i got under the truck to see what i could of the manifolds and cant see soot down there it starts a little ways up the the prob wire i have had people tell me they think my y pipe is leaking or cracked they dident think it was my manifold beacause it dosent seem to be low on power and they thought it would be if it were the manifold can someone maybe give me another answer or confirm its the y pipe
Old 10-31-2010, 11:06 AM
Illiana Chapter Director
It's more than likely the flex joint on the "y" pipe. I have seen a couple manifolds leaking and Ford does have manifold gaskets for them now. They are built without manifold gaskets.
Old 10-31-2010, 07:35 PM
will check into it ig i will just take it to a local exhaust shop anyone else have another opinion
Old 11-01-2010, 07:58 AM
You have a leak in your up pipe or y pipe. And on the manifolds, I got under my truck to do my EGR delete and noticed my exhaust manifolds on both sides had finger loose bolts in them.
Old 11-01-2010, 08:36 AM
I might be able to help if I could follow what you're asking without making my eyes and head hurt
I think I found one capital letter.
Old 11-01-2010, 08:54 AM
im sure the op appreciates this insightful information u have graciously added to the post.
to the op, u def have a cracked/loose y pipe and or loose exhaust manifold.
Old 11-01-2010, 09:23 AM
No insight needed. Its glaringly obvious. I'd bet my house that I'm not the only person who had trouble reading that. After seeing your post, it also obvious why you had no trouble interpreting.
Old 11-01-2010, 09:33 AM
No insight needed. Its glaringly obvious. I'd bet my house that I'm not the only person who had trouble reading that. After seeing your post, it's also obvious why you had no trouble interpreting.
You're not perfect either. I understood the post perfectly clear and i'm a very smart guy and use "big" words in everyday converation. I sometimes don't type things out perfectly either, when i'm in a rush i leave lots of things out to make up time. Maybe he was busy at the time of the post. Whatever the case. I think it would have been better to return to the previous page instead of post a comment.
Old 11-01-2010, 09:39 AM
No insight needed. Its(you forgot your apostrophe here) glaringly obvious. I'd bet my house that I'm not the only person who had trouble reading that. After seeing your post, it(you also forgot your apostrophe and the s here) also obvious why you had no trouble interpreting.
keeping this on topic, you should start the truck and have a friend rev it and see if you can pinpoint the exact location of the smoke.
Old 11-01-2010, 10:07 AM
I never said I was, and I know I don't type things perfectly. And I'm probably not as smart as you or a lot of other people on this board. Most of the words I use have less than 3 syllables. But there are a lot of people who won't take the time to finish reading his post due to the lack of clarity (capitalization and punctuation). And he may not get the assistance or advice he's seeking. Not this time, and possibly not the next time he has a question.
Definitely the way to go.
