Power steering leak kit to fix and flush how much fluid
hi
my 05 6.0 has developed a powers steering leak at the hydroboost...the dealer said there is an kit that will fix this problem... part number 6C3Z-3F887-C ---- hose kit and 388897 Is this difficult job Also...I'm going to change the fluid...is there a "easy" way to do this....how much fluid will the 6.0 need....and what fluid should i use....Mercon V or Amsoil full syn ATF or Mobil 1 full syn ATF ???? thanks alot |
bump bump bump
Do not put any other Trans Fuild in your trans, as for the PS its not hard but the fitting down below on the box itself is a pain to get to, you need like a short wrench or one cut in half.
thanks for the reply
