Restore coolant cleaner - Ford Powerstroke Diesel Forum
Old 10-29-2010, 04:39 PM
Does anyone know how much restore to use when doing a coolant flush? And does it matter if you use it before or after VC9?
Old 10-29-2010, 04:46 PM
The label says 1 gallon of restore will work with up to 10 gallons of water. So I am gonna dump the whole gallon in. I read on here to use the VC-9 first, drain, then do the restore.
Old 10-29-2010, 05:46 PM
Yes and you want to add the restore to water and flush not antifreeze, so flush the coolant out before throwing the Restore in.
Old 10-29-2010, 07:48 PM
I'm having my diesel mechanic flush and clean the cooling system in my 2006 6.0 with Restore next Wednesday (made the appt today) and he will be refilling with an ELC. I just flushed and refilled the cooling system earlier this summer with the Ford Gold crap........you live and learn.
Old 10-30-2010, 12:51 PM
How long do you run the RESTORE in engine? Is it similar to the VC-9 as far as fill it, run it till hot and then flush it, repeat untill clean?
I also read about and heard of the "VC-9 +" is this stuff an all in one instead of restore and VC-9. Or is doing both treatments seperate better??
Looking forward to getting all the junk out of the engine and cooling system!!
Old 10-30-2010, 02:20 PM
I have heard to use both. If i am correct VC9 first (Iron system cleaner) then Restore (removes silicate gel and oil and grease super cleaner) then distilled water until clear.
Old 10-30-2010, 05:49 PM
where can you buy restore??
I was also wondering how long to run the engine with the restore as well...
thanks
Old 10-30-2010, 07:51 PM
thanks
Try this.....http://www.fleetguard.com/wrl/retail...tion=getregion
Old 11-01-2010, 11:27 AM
I did my restore flush first after flushing out the old coolant and ran it for 90 minutes.
You can get it HERE
Old 11-01-2010, 12:36 PM
NOT a Democrat
You can get it HERE
After the restore and the water, how many times did you flush after the restore?
