VC-9? and Blackstone? - Ford Powerstroke Diesel Forum
Old 10-28-2010, 10:36 PM
Were do you find VC-9 for purchase?? I was thinking about having a oil analysis done on the truck I just bought. Is having the old oil analyized worth doing??
Thanks again
Old 10-28-2010, 11:26 PM
that shouldnt be an issue. if you dont the first or second oil change you do will work as well.
vc-9 can be bought at ford. and thats a coolant flush.
http://www.thedieselstop.com/forums/...ok-pic-253753/
Old 10-28-2010, 11:29 PM
Buy vc-9 at dealer, around $25 per quart. You need 2 for a flush. Also, you might want to do a search on "Restore" . I've read that it gets rid of the silicates the Ford coolant drops out. And the silicates plug the oil cooler.
And here is a list of threads you might want to keep around.:
new guy need some help please! - Ford Truck Enthusiasts Forums
Old 10-29-2010, 07:37 AM
Thanks again
It is the used oil that you want to have analysed. That will let you know if anything abnormal is happening in your engine.
As stated the VC-9 is a coolant flush intended to remove iron and mineral deposits from the cooling system.
Restore is formulated specifically for clearing out silicate sludge.
Restore Plus is the same thing as VC-9.
Old 10-29-2010, 09:23 AM
The "old" oil is still in your truck now? Yes having it analyzed will help you to know the current state of your engine and how the oil is doing.
