tow haul
when do you have to use this feature? is it when you have alot of weight or any weight? or what if your towing a empty trailor about 2000lbs? any input would be helpful
2000 lbs tow haul is not necessary. use it when it starts hunting for gears or trans temps climb. on
I would use it with 5000 + lbs.
Heck, I use it just driving around town with no trailer, saves brakes.
I'm getting more used to it, both with and without trailer, it's a cool feature.
What exactly does this do? Dealer said it simply shifts firmer, is that true? I guess I'm use to gas engines where it simply keeps it from going into overdrive.
I use it any time I tow anything with 2 or more axles.
Larry |
so would it be bad to use without any weight other then using a little more gas due to the higher rpms between shifts
Not really - lots of times when I'm in stop and go traffic or even just slow traffic, I'll engage it so i don't have to use my brakes as much.
