Coolant flush procedure - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-26-2010, 02:48 PM Thread Starter
blackshadow's Avatar
I know For has a 6.0 L Diesel cooling system contamination flush procedure, but what about the shops that have the machines that vacuum or however they do it? Has anyone ever used that? Also Fords procedure talks about using VC-9 but doesn't say anything about Restore. Any input on the procedure of using them both? Switching to the ELC and shop owner says he has that machine and it should be easier. I just wanted to know if I still need 22-24 gallons of distilled water, 2 quarts of VC-9, and 1 gallon of restore if using the machine?
blackshadow is offline
post #2 of 2 Old 10-26-2010, 05:15 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I believe you at least should use the VC-9. I don't know enough about the Restore, but have heard it works real well for getting rid of the silicates that the Ford coolant has in it.
Here is a link:
Coolant Change 101 - Ford Truck Enthusiasts Forums
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
