Stuck gas mileage
I can't call it bad considering what I came from. What I have is a 2005 F350, CC Long bed, dually, 4x4, 6.0 and a 4.10 rear end. It gets 10 MPG, maybe 11 if I'm lucky. I can be pulling my 7000 lbs camper or running empty, it's 10 MPG by the trucks calculations and by my hand calculations. I can drive like an old man or like a mad man and it's the same thing, 10, maybe 11. I know it's a 1 ton, it long and big and a 4x4 but shouldn't I be getting something more than 10 mpg. I may have a turbo issue thats causing the wrench light to pop on when towing (I have another post on that issue ongoing). I bought the truck with 84K miles, it was supposed to have it's oil changed then but don't know what kind is in there. I replaced the fuel and transmission filters. Replaced the EGR valve too. Only thing left is the airfilter and ??? I'm wondering if I have an injector issue here.
Any ideas? Thanks Fred |
Wow, that doesnt seem right to me. I am running an 04 dually, lifted on 36's, and i run the piss out of mine 50% of the time to keep the turbo healthy, and i get 11.5 on the overhead, and if i manually calculate anywhere from 11.8-12.6
To start with i would change the oil so you know what is in there and use only Ford filters. You can go to WalMart and get a Ford filter and MotorCraft oil 5 qts to a jug 3 will do it then you will know you have the right oil in it or go with a good Syn oil just need 15 quarts. If it was at a dealer they may have flashed it then you may need a tuner to improve your mileage, this may help![]() 2 stroker |
Speed kill mpgs on these trucks. My first tip for calculating mpg. Fill the tank full. From the first click on my truck to the filler neck is between 6-10 gallons. Get a good base line to start with. Not getting a full take or incosistant fuel levels will get out thrown off numbers.
Go to a gas station by a highway, and fill up your tank ALL THE WAY UP to until you can see fuel in the filler tube (obviously without spilling). Just listen closely while filling and you will be able to hear it coming close to the top. After the first click it will definitely take a lot of fuel still. Then, go hop on the highway and set your cruise to around 65mph, which should put you around 1900rpm I think. make sure there is no traffic. Drive for about 30-40 miles and then stop at the gas stn and fill up again to the same line. This number, empty, should be MUCH higher than 11mpg. Do it all manual calculations, not the stupid computer. If it is not much higher, then you've got a problem. When I did this, I got 19.3mpg. |
i will agree with that vid EXCEPT, put the pyro BEFORE the turbo. not after it
So, when the filling up and it shuts off, keep pumping til it fills the neck? Thats a new one for me. My 38 gallon tank could actually be a 46 to 48 gallon tank? |
I do it everytime I go to the gas station now because like the poster above I found that my truck can take about 4-5 more gallons after the first click and it means less stops to the pump. It really depends on the gas station though, some stations click earlier, some later. That is why this is the only true way to determine gas mileage.
