Coolant Temperatue affected by Air Temp? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-26-2010, 08:52 AM Thread Starter
Switchrider900's Avatar
I'm kind of wondering if the coolant temperature is affected overall by what the temperature of the air is outside?
Here is why I'm asking, my oil temp and coolant temp have usually about 6 - 9 degrees of difference. I run a Evolution for gauges only!!! Then when I'm on the highway the difference goes up to about 11 degrees. I know and have read what it should around 5 depending on what you are doing. My driving is mostly crusing and not pulling anything.
Would the temp of the air affect the coolant temp? I also have a zoodad mode on my truck also. Before I go ripping into my truck, just want to cover the basics. Did the zoodad mode before I had guages, so not really sure what the temp was before the mod, and if it really does affect the temp.
My temps hardly ever get above 200*, and if they do it's not for long.
Thanks for the feedback.
Mods:
High Idle Mod
Reverse Back Up Camera
Aftermarket Exhaust
Edge Evolution
Big Rig lights
Zoodad Mod
EGR Delete
Bocar Push Bumper
Levelling Kit
Blue Spring Upgrade
PMM Coolant Bypass kit
Want:
New Steering Wheel
Switchrider900 is offline
post #2 of 4 Old 10-26-2010, 09:38 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Your temps might be slightly high but you are still in the normal zone. The temp delta that says rebuild the oil cooler is 15 degrees. Just keep an eye on it and if the delta keeps increasing plan for an oil cooler rebuild when it gets over 15.
RIP Mitch
the Org crew
PGreenSVT is offline
post #3 of 4 Old 10-26-2010, 09:39 AM
bfrank81's Avatar
Yes it will. While driving on a trip on the highway I noticed an increase of 10* in ECT / 1* of IAT increase.
Brian
bfrank81 is offline
post #4 of 4 Old 10-27-2010, 12:23 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 132 Post(s)
I use a Aeroforce Gauge to read IAT1/IAT2 and ECT. I have the digital AC control that shows what the trucks reads as OAT.
If you consider they share OAT as an constant the following must be true.. Low OAT will contribue to low IAT1/IAT2 readings as well as ECT readings. IAT1/IAT2 temps will not effect the ECT readings nor will ECT effect IAT1/IAT2 readings.
I disagree that you will have LOWER ECT/EOT temps on the HWY since the truck is running harder.
Yes OAT will effect ECT. Cooler OAT will lower ECT as well as higher OAT will increase the ECT. I find OAT around 50*F will keep my ECT well below 190*F routinely, OAT over 90*F will keep my ECT over 195*F.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
