2004 vs 2005 GVWR - Ford Powerstroke Diesel Forum
post #1 of 26 Old 10-26-2010, 05:15 AM Thread Starter
2004 vs 2005 GVWR
My truck is a 2004 F350, 6.0. The GVWR is 9900lbs.
2005, with the same options - f350, powerstroke, is ratted for 11,200.
wtf!?
I know legally I'm done at 9900, but what makes the 2005 different? Frame? Springs? What?
After buying this truck (and hearing lots of head gasket issues), I quickly realized that with a 9900lbs gvwr, and a curb weight of about 6200lbs I can't put much in the bed. Thinking of getting rid of this truck now.
Any insight appreciated. New ford guy here. Thinking of going back to Chevy.
-- Joe
anesthes is offline
post #2 of 26 Old 10-26-2010, 05:21 AM
LNS4x4's Avatar
Mines is at 11,500 I believe. I'm not sure what the difference is, but I found out after I bought the truck that I had to get commercial plate in Massachusettes because of my weight.
2005 6.0 PSD XLT SD FX4 CC LB
Engine:
SCT, SRL, Atlas 80, Arp's, Bulletproof Oil cooler w/ Cold weather package, All aluminum radiator, Bulletproof water pump, Sinister Full Delete, 4" Mbrp turbo-back, Banks Techni-Cooler, Banks intake, Edge insight CTS, Diesel site coolant filtration, CCV Mod.
Suspension:
2.5 Icon Leveling kit, 5" Icon rear block, Pure Performance adjustable trackbar, King shocks, PMF 3 link.
LNS4x4 is offline
post #3 of 26 Old 10-26-2010, 05:25 AM Thread Starter
Yeah, I'm in New Hampshire. It doesn't really matter up here. I know when I lived in MA it was 10000lbs or 6 wheels = commercial.
But anyhow. I'd love to know what the difference is. If it's helper springs or the 17 inch tires or whatnot. Whatever it is, I'd like to either do it to my truck or replace the truck. I need to haul 4,000lbs of 'stuff' in the bed.
-- Joe
anesthes is offline
post #4 of 26 Old 10-26-2010, 06:10 AM
topdwg's Avatar
Click here https://www.fleet.ford.com/showroom/...04_default.asp you'll find everything you need to know. Hope it helps...
2012 F-350 SRW King Ranch
SOLD - 2004 Lariat F-250 4x4
6.5 Pro Comp Lift W/ Fox Shocks, DeeZee Tool Box, 08 Diff. Cover, 37x13.5/20's Pro Comps, Zoodad Mod, SCT w/custom tunes, 4 in EX., AFE Intake, ARP, Recon Lights, High Idle Mod, RCD EGR Delete, Fumoto Valve, Oil Bypass Kit, 03 Turbo, Yukon Gears, Farmboy Stage II Traction Bars, Dieselsite Coolant Kit, Amsoil, HIDS, Edge Insight CS, PHP FICM
topdwg is offline
post #5 of 26 Old 10-26-2010, 06:19 AM Thread Starter
Thank you for the link, however that is related to towing not payload capacities.
I'm curious what makes a 2004/2005 different that the axles can handle more in 2005.
-- Joe
anesthes is offline
post #6 of 26 Old 10-26-2010, 06:38 AM
topdwg's Avatar
Sorry about that. First off when you say F-350 are you talking about SRW or DRW?
topdwg is offline
post #7 of 26 Old 10-26-2010, 06:41 AM
topdwg's Avatar
Also 4x4 or 4x2? Because the 4x2 SRW regular cab has a a GVWR of 9900 pounds, but the 4x2 DRW regular cab has a GVWR of 11,200.
topdwg is offline
post #8 of 26 Old 10-26-2010, 06:46 AM
topdwg's Avatar
Also gear size makes a difference, 3:73 or 4:10s.
topdwg is offline
post #9 of 26 Old 10-26-2010, 06:47 AM Thread Starter
Also 4x4 or 4x2? These things make a difference...
Sorry.
It is a SRW, 4x4, 8 foot bed, regular cab. According to all the charts, etc 2004 optioned 'that way' is rated for 9,900lbs.
In 2005, the rating soars to 11,200lbs. I realize the 2005+ models have front coil springs, so the frame must be slightly different. I'm guessing since the GVWR is 1300lbs higher, they must have made some major changes.
I have the 10.5 sterling axle, which I believe is the same axle in the 2005-2007 models, so I'm curious what exactly makes a 2005+ have such a higher GVWR.
-- Joe
anesthes is offline
post #10 of 26 Old 10-26-2010, 07:00 AM
topdwg's Avatar
See if this helps:
05 Specs
https://www.fleet.ford.com/truckbbas...essd-exlbb.pdf
04 Specs
https://www.fleet.ford.com/truckbbas...essd_04abb.pdf
topdwg is offline
