05 excursion not starting
Hey guys I am having an issue with a buddy's truck here. I am a gm mechanic and have no issues getting into things but this truck has me stumped.
Just a brief history, this was running down the highway and started to lose power, not running rough, just low on power and speed. Then it went away. The guy said he did notice that it sounded like the turbo whistle had gone away during the low power condition. Once it regained power he cruised for approx 10 miles and went poof, literally, truck stalled and wont fire. I was suspect of the oil system because I was not seeing any oil pressure register on the ipc when it was cranking. I was going to start with the basics, and do an oil change.
When I took the oil filter cap off, the filter looked like it had been sucked in, but more importantly, the whole inside of the cap where the filter slides on was melted/gone. I found a bunch of melted plastic on the bottom where the filter slides over also.
I have since gotten the turbo off and was going to start removing the oil cooler, was going to look into replacing the egr cooler as there is no coolant in the degas tank, or it doesnt seem like in the engine so far. The oil reaks of burnt ****. I am thinking that the thing was run without coolant and just got real freekin hot. I am worried about the oil filter cap plastic is what is causing the no oil pressure so thats why I was heading that way.
Any thoughts on what to look for, have you guys ever seen something like this? Just from the reading I have done over the weekend the egr coolers seem like a huge issue, this on is stock oem. Also looks like the low oil pressure pump may be shot. Along with the cooler.
Thanks in advance guys, any info you need please ask away. I want to get this guys truck fixed for him. Its had a good life thus far and always stock.
