Tire Size with 4" lift - Ford Powerstroke Diesel Forum
Old 10-25-2010, 10:05 AM
Has anyone tried or is it possible to fit 37" tires with a 4 inch lift? i have an 06 with the stock radius arms. I have 35 12.50 on it now and think that it looks too small. bought the truck that way. its got mud terrains on it now but i am going to go with an AT when these wear out. it has 18's if that helps and the tires stick out about 2 inches from the body.
Old 10-25-2010, 10:48 AM
on stock wheels a 37 will fit. i'd stick with a 12.5" wide tire though if it was me
Old 10-26-2010, 01:18 PM
a 35 12.50 will fit and slightly rub with just a coil spacer. so i dont see why a 4" lift wouldnt clear 37s. lets see some pics when ur done
Old 10-26-2010, 01:38 PM
As said, you will be fine. there are a couple guys on here running 37s with only a leveling kit
