Parking brakes on f-250
hello
does anyone have a diagram of how the parking brakes go back together on a 2005 f250 parking brakes go inside rear rotor. any pics could help. thanks chris |
This file is for a 2007. I'll try to attach to is post.
Can you post the section on Parking Brake Shoe Adjustment? My 2002 F-250 is giving me a fit.
Also, when I engage it, there is no light on the dash. Shouldn't there be one for the Parking Brake? Thanx in advance. |
The parking brake is just a regular drum brake inside the rotor. There is a window on the lower side of the backing plate that provides access to the star adjuster between the lower part of the shoes. Take the rubber cap out and use a brake spoon to adjust the shoes to the proper tension. If you don't have a brake spoon you can do it with a flat bladed screw driver.
You gotta go old school man. |
I adjusted both sides until I started getting some resistance on the pedal, then backed off about 4-5 clicks. It was working OK when I put the wheels back on. Now, a few days later, it's back to working like crap. Any other advice for a F-250 noob? |
They should adjust automatically when you press on the brake while going in reverse. Get them set again and do a few reverse stops and see if it doesn't help.
Going out right now to try it, and if it works I'll be back to eat my words and sing your praises. |
