ABS light stays on, common issue? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-24-2010, 10:47 PM Thread Starter
14mins's Avatar
My ABS light now stays on all the time. For a few weeks it would come and go. Sometimes it would work and then other times it would not. It is now in the does not work mode. Where do i start? I would guess the controller under the hood is bad? In the past i have replaced a fuel injector on the drivers side, not sure if that is related but seems to have started shortly after that. How do you diagnose these ABS problems and what kind of price range to fix this?? I kind of like the peace of mind knowing the ABS works when needed. Thanks.
2005 YELLOW f250, REMOVED PROGRAMMER, yellow guage cluster background, JL 5 channel amp, Infinity speakers, JL sub in custom box, aftermarket seat heaters, cab lights, 3 inch Lift. idle mod, 35 inch tires. 1979 YELLOW Corvette, 2005 YELLOW Dodge SRT 4 TURBO Neon, 2005 YELLOW Monte Carlo SS and a 1987 Buick Grand National for when the NEED FOR SPEED hits. I have dreams of painting this car YELLOW!!!!!!!!!!!!!!!!!!!!!!
14mins is offline
post #2 of 4 Old 10-25-2010, 09:10 AM
pby98's Avatar
mine does the same thing. Every now and then it will come on but eventually goes off.
2006 f250 CC LB 4x4 6.0
XL interior
high idle mod
silverline custom straight pipe mid dump
08 tailgate, bed, rear bumper, tailights
recon led clearance and 3rd brake light
line x rockers
harley headlights
hellas behind grill
edge juice with attitude
limo tint
pby98 is offline
post #3 of 4 Old 10-25-2010, 11:42 AM
C-5 Crew Chief
Mattdc26's Avatar
Send a message via AIM to Mattdc26
same here dealer (also a friend) said its no big deal i just dont have ABS which i dont want anyways but im sure a tech could help with more info
05 250
Muffler-MBRP Free Flow
Kitty-Gone
MBRP Turbo Back
ARP Studded
Blocked
DieselSite Trans Filter
NUC Motorsports Bypass Filter
ZooDad Best MOD
CAT ELC
Livewire
Custom Tunes From Innovative
Mattdc26 is offline
post #4 of 4 Old 10-25-2010, 11:49 AM
excursionMark's Avatar
Send a message via Skype™ to excursionMark
check the fuse and the 3 sensors (front hubs and rear on top of the diff)
2000 Ford Excursion
7.3L Powerstroke Diesel~DP Tuner (Stock.Drive Thru.High Idle 1400.80 Economy.120 Race)~05 front end~DIY AFE Pro Dry S Intake~Viper Alarm/Remote Start~55w 8000k HID~Whelen Strobes~Pioneer AVH4100~Alpine Type X Component Speakers~2x12 Type X Subwoofers~Alpine PDX 1.1000 Amplifier~Custom Center Console
excursionMark is offline
