Oil in cylinders - Ford Powerstroke Diesel Forum
Old 10-22-2010, 07:22 PM
Oil in cylinders
Trying to pinpoint the white smoke and rough running of my 04 6.0. As stated before, while cold, getting white smoke out tailpipe & raw fuel. Pullin glow plugs as we speak, 2 and 4 are covered in oil, 6 and 8 are clean. Doing the d/s bank as i write. Any ideas? No codes. Bad injector o ring/failed injector?
Thanks guys!
Old 10-22-2010, 07:29 PM
Thanks guys!
Bad EGR Mine would fill the parking lot with white smoke.
Old 10-22-2010, 07:33 PM
How about the oil in certain cylinders? And I removed the egr valve and it is dry in there? Thanks for the quick reply!
Old 10-22-2010, 07:41 PM
The white smoke is steam from coolant i know that. Oil in the cylinders don't know?? I know they say to do the oil cooler when you do the EGR delete because if your ERG cooler is shoot 9 times out of ten the oil cooler is on the way!! Someone will post more info i am sure. I know mine smoked like a steam powered train and it was my EGR never looked at the cylinders .
Old 10-22-2010, 07:49 PM
How about the oil in certain cylinders? And I removed the erg valve and it is dry in there? Thanks for the quick reply!
I do not think it is the EGR if the valve is dry. A bad egr will usually look wet or like it was steam cleaned.
Old 10-22-2010, 07:53 PM
What else would make white smoke??
Old 10-22-2010, 07:56 PM
Raw fuel from a stuck open injector? Could oil be leaking into the cylinders from the glow plug connector inwards? Seems unlikely?
Old 10-22-2010, 07:59 PM
Dont think fuel would be white. More fuel = black smoke at least thats my understanding. And seems very unlikely??
Old 10-22-2010, 08:32 PM
White smoke is usually steam. When coolant is leaked into the exhaust, it vaporizes, or turns to steam, and comes out the exhaust.
Old 10-22-2010, 08:38 PM
Just checked scanner. At running temp, engine coolant temp is 176, engine oil is 110. Should there be such a difference between the two?
