Testing FICM ? - Ford Powerstroke Diesel Forum
Old 10-20-2010, 02:33 PM
Testing FICM ?
When testing the FICM does it matter if its cold or warmed up? I searched and some say warmed up and some say cold.
Old 10-20-2010, 03:34 PM
Cynic
If you see a voltage drop cold or hot, then it is bad. But, if the FICM is bad, how would you test it warmed up?
Remove it, toss it in an oven?
Old 10-20-2010, 03:35 PM
Cynic
Also, MAKE SURE your batteries are good. Test them off the truck. I've seen bad batteries cause people (even techs) to replace a FICM.
Old 10-20-2010, 04:03 PM
I worded that wrong I meant like if the truck is warm or cold
Old 10-20-2010, 04:12 PM
Cynic
OK, back to my original statement. "If you see a voltage drop cold or hot, then it is bad. But, if the FICM is bad, how would you test it warmed up? "
General rule, FICM goes out, you have a no start or a real hard start and you'll throw a code. And also as a general rule, if you see voltage drop, FICM is bad or about to have a quick death.
Old 10-20-2010, 04:30 PM
I say test it under the conditions that match when the problem exists.
The write-ups I have seen are for long crank times when cold, so thats when they recommend testing.
Old 10-20-2010, 05:11 PM
Ok ya when mine has set over night and I go to start it to leave for work it will start die and repeat a couple times then fire up. Then will run with like half power till warmed up. After that I can turn it off and start it with no problems till it sets for along time again.
