Add VGT Cycle Back to Custom Program - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-20-2010, 11:54 AM Thread Starter
Special's Avatar
Quoted: 2 Post(s)
Question Add VGT Cycle Back to Custom Program
I am running Extreme Street all the time and would like to have Innovative add the VGT cycle back into my Extreme Street program. I miss hearing the cycle, I thought it was cool, and I want to help prevent the turbo veins from sticking like the program was designed to do. I would like the VGT to cycle about every 10 sec anytime the truck is in park and at idle. Has anyone else done this? Is this a good idea or will it cause any problems?
2005 Stampede Edition F-250 SuperDuty 6.SLO Diesel
4" Lift on 37" Toyo MTs ( IT CAN BE DONE ! )
Barder Stage 2 Turbo-Warren 175/30 Injectors-WPE Stage 3 Intake-DD RR-CTS2 Monitor-ARP Studs-BPD Remote Oil Cooler-Amsoil Custom 2 micron Full Flow Oil Filters-Sinister(Coolant Filter & CAC Pipes)-CCV Mod-Special's Fenderwell Mod-4:30 Gears-Grizzly Locker-Custom 5" Dual Straight Pipe Exhaust-AFE Momentum Intake-SCT Custom Tuned-Kleinn(630 Train Horns & Onboard Air)-HIDs-JL Audio-and Zoodad.
Special is offline
post #2 of 11 Old 10-20-2010, 12:18 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Is your EGR valve unplugged?
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #3 of 11 Old 10-20-2010, 12:20 PM Thread Starter
Special's Avatar
Quoted: 2 Post(s)
No. I have a EGR Delete Kit but have not installed it yet.
Special is offline
post #4 of 11 Old 10-20-2010, 01:09 PM
tuckman's Avatar
That is a cool idea, I am going to shoot an email over to Vivian @ QuickTricks and see if she can do something like that.
2005 Excursion Limited 6.0 4X4
PHP tuned Swamps 58v FICM
Edge Insight CS, with universal 0-100psi sensor for fuel pressure
SCT tunes by Quick Tricks and Gearhead
Sinister EGR Delete and Coolant filtration kit w/Cat EC-1
6.4 banjo bolts
Ford fuel pressure spring kit
High Idle Mod
ARP head studs
Magnaflow 4" turbo back w/muffler
Powermax turbo
Firestone Ride-Rite air bags
Retro Solutions 55w 4300k digital HID's
Clarion NX500 double din DVD/Nav
tuckman is offline
post #5 of 11 Old 10-20-2010, 01:27 PM
IIRC, it Depends on what strategy you have to begin with.
Blake
post #6 of 11 Old 10-20-2010, 01:28 PM Thread Starter
Special's Avatar
Quoted: 2 Post(s)
Tuckman, let me know what you hear. I e-mailed Innovative, but have not got a reply yet. I will keep this thread up to date with what I learn. Does anyone else have any experience in this area?
Special is offline
post #7 of 11 Old 10-20-2010, 02:03 PM
I talked to Eric about this a while back. If your stock tune will do it, then it should do it with the tune. The only way it shouldn't is if your EGR is unplugged.
Blake
post #8 of 11 Old 10-20-2010, 04:19 PM Thread Starter
Special's Avatar
Quoted: 2 Post(s)
It did it with the stock tune but does not do it with Extreme Street. My EGR is plugged up, but I believe the custom tune keeps it closed. I feel sure that the custom tune does not include the VGT cycle.
I don't see why it can't be added back and if it does not have any bad side effects I want to try it.
Special is offline
post #9 of 11 Old 10-20-2010, 05:10 PM
back to business
07OUTLAW's Avatar
My SRL from Matt cycles the turbo just like stock
You're going to need a new tune written with VXCF9xx as the base, I'm guessing.
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #10 of 11 Old 10-20-2010, 07:50 PM
My Xtreme Street does it. Not sure why yours doesn't.
Blake
