front end help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 10-19-2010, 12:03 PM Thread Starter
luckyJ's Avatar
front end help
ive got an 04 F-350 dually with almost 150,000 miles on it. its starting to get some slack in the steering, misc. bumps, and so on. im going to order parts in the next few days when i go back to work, that way theyll be there when i get home to slap em in. my question is, what all should i replace while im in there? not sure what alls bad or needs replaced, just figured since its gonna be tore down i should replace most of what i could. im thinking wheel bearings, tie rods, ball joints, check u-joints in axles and front driveshaft. what else should i look into or order? if i order the part and its not in need of replacing, then ill just have a spare for next time. what yall think? any help is greatly appreciated!
04 F350 dually
& a few other toys
luckyJ is offline
post #2 of 5 Old 10-19-2010, 12:18 PM
duct tape & zip ties
bigcountrysg's Avatar
Well with out inspecting it, tie rods outers inners all of them. Ball joints upper and lower.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 5 Old 10-19-2010, 05:30 PM Thread Starter
luckyJ's Avatar
what about the drag link or whatever ford calls em? i think i might go ahead and order a leveling kit and track bar while im at it. gonna get it aligned and tires rotated and balanced too. is there anything else im missing?
04 F350 dually
& a few other toys
luckyJ is offline
post #4 of 5 Old 10-19-2010, 07:07 PM
DerwoodF350's Avatar
Well I haven't done any front end work on mine yet but the front end guy that did my alignment said if you do the ball joints you should put in new grease-able front U joints while the ball joints are out cause they need to be out to change the U joints anyway.
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD X-hale exhaust(JUNK), RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire, Liberator Y pipe, Dieselsites Coolant filter & Delo ELC, Zoodad mod, Swamps HOT FICM, Matts SRL++ & tow tunes
, CCV Mod, CompuStar 2way alarm/remote start
To do list: fluids changed out to synthetic,HID's, .
DerwoodF350 is offline
post #5 of 5 Old 10-19-2010, 07:11 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
While your under it, check your sway bar bushings.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
