high idle mod with lighted switch? - Ford Powerstroke Diesel Forum
Old 10-16-2010, 08:41 PM
Has anyone used a lighted switch on there high idle? I have a pilot led touch switch that i want to wire to it, but i can't get it to work. The switch has three poles but i only have to wires to connect. Can any one help me with this? Any help at all would be appreciated.
Old 10-16-2010, 08:54 PM
you have to ground the switch for the light to work.
Old 10-17-2010, 06:45 AM
I had the same issue. On the switch I used, the post nearest the light goes to ground.
Old 10-17-2010, 07:38 AM
yep it needs to be grounded.
Old 10-17-2010, 08:03 AM
check my pics i used one and took pics of the ground
Old 10-17-2010, 08:05 AM
Feedback Score: 9 reviews
Where do you route the ground wire too?
Old 10-17-2010, 08:09 AM
ok so i checked my pictures and there gone. Anyhow when you pull the cover off that conceals the wires under your steering wheel you will see the ground location. It is just to the right of wheel your right leg would be while driving, you will see two green wires which are grounded to the metal. Losen one up, put your ground in with it and tighten it back down.
Old 10-17-2010, 06:25 PM
mine has to lights on it. a red one while its off and blue when its on. i tried grounding it but couldnt get it to work. the three post are V+,V-, and V+ out.I grounded the V- post and it wouldnt do a thing. i tried another switch to see if the switch was bad but it wouldnt work either. heres a link to a video of how the switch is suppose to work.
Old 10-18-2010, 01:27 PM
Some ones gotta know how to wire this thing. Anyone?
Old 10-18-2010, 08:18 PM
Not sure what kind of switch you're dealing with. Easiest way to figure it out is to use an Ohm meter across the various combinations of posts and flip the switch to see where you have continuity.
If I had to guess though, V+ will be your fused 12vDC power source (e.g. battery), V+out will be to the high idle circuit, and V- will be to ground.
Lastly, you are using a 12vDC rated switch, right? You can get 120vAC rated switches. They use a neon light rather than LED. You'll have continuity across the switch but you'll never light the neon off with 12vDC.
