Upfitter Switches Installed - Ford Powerstroke Diesel Forum
Old 10-16-2010, 09:04 AM
I just purchased the Upfitter Switches and wiring harness, and installed it last night. There are a Red, White, Blue, and Black wire in the engine compartment, that feed through the firewall to a bundle just under the steering column. These wires were meant to be used with the Upfitter Switches, to control any additional accessories. The bundle of wires located near the steering column is called the Customer Access bundle, or CASC. In this bundle are a bunch of other wires that are "capped" off. Amongst them, is one thats Purple/Light Green, which is the High Idle Circuit that you connect to the AUX4 switch. The others Im not sure. Knocked down several birds with one stone on this one. Got the Upfitter Switches installed, installed my rear off-road lights (For connecting/disconnecting my travel trailer in the dark), and did the High Idle Mod, all in about 2 hours.
Old 10-17-2010, 08:41 AM
Show us your switches! Did they come as a pack or did you just mount multiple switches?
Old 10-18-2010, 11:11 AM
I hate to sound dumb, but I am new. What are upfitter switches, what are they used for?
Old 10-18-2010, 12:49 PM
They are lighted aux. switches that can be used by the owner to hook up accessories like extra lights, train horns, high idle mod. Anything that requires a powered switched source to operate. They go into the slot next to the trailer brake bias adjuster if you have one.
Old 10-18-2010, 06:26 PM
i have those switches on my truck , what do i need to do to make the high idle mod run off of one of these switches.
Old 10-18-2010, 06:31 PM
Hooking up high idle w/upfitter switches - Ford Truck Enthusiasts Forums
Old 10-18-2010, 06:43 PM
thank you majorleaguebass
Old 10-21-2010, 10:09 AM
Pics??? I know what the wires look like I have the same ones!
Old 10-22-2010, 01:21 PM
Old 10-22-2010, 01:51 PM
Originally Posted by mah77 View Post
NICE! I have that stupid shelf thing in that same spot. Does anyone know if you can buy the switches without the brake controller?
