Fuel In The Oil Pan - Ford Powerstroke Diesel Forum
Old 10-15-2010, 04:25 PM
Angry Fuel In The Oil Pan
I searched for this answer but no luck! I changed oil yesterday on a 2004 with no mods and I had close to 2 gallon of diesel in the oil pan. I had the FICM go out in June. I'm open for suggestions. Injector, O-ring, FICM, bad ring,....
Old 10-15-2010, 04:28 PM
shaking things up
might be an injector o-ring
Old 10-15-2010, 04:32 PM
I already tried that test and all was good.
Old 10-15-2010, 05:02 PM
shaking things up
hmmm maybe an injector is stuck open and flooding out? also do a compression test on the motor it will tell you if something is bad with a piston or ring
Old 10-16-2010, 04:21 AM
7 minutes after you originally posted you have already tested for leaking injector o-rings??? How did you do it?
