Coolant Filter Idea - Ford Powerstroke Diesel Forum
post #1 of 21 Old 10-13-2010, 07:26 PM Thread Starter
Coolant Filter Idea
I'm getting ready to add a coolant filter to my X. I have been reading a lot on here about them and researching different ones. However, tonight an idea hit me. Why couldn't I just take a remote oil filter kit (like this) and put it in my heater line? Seems to me like it would do the same thing, and the filters would be easy to find and buy. Am I missing something, or would this be a good (and even better CHEAP) route to go?
2004 Ford Excursion Limited
6.0 Turbo PSD (Late Build)
mwcooke is offline
post #2 of 21 Old 10-13-2010, 07:36 PM
bwillis2003's Avatar
ya this is a guy on here that made a real nice kit for like 50 bucks, if you got the time, go for it! I got a Dfuser one, love it, but the ss bracket that hold these things are flimsy if u ask me
Brandon
2007 F-250 6 point oh
146,000 miles
2.5 inch BDS leveling kit
35" Toyo Open Country A/T
OEM rotors w/ Hawk LTS pads
5 inch custom sidepipe
Edge Insight CTS
SCT X3 w/ Innovative Tunes
ARP headstuds
Bilstein 5100s
Banjo Bolts
NCHornet's CCV Mod
Dieselsite Boots
EGR Delete
FICM fixed by Ed/tuned by PHP
S&B Intake
Dfuser Coolant Filter Kit
2003 F-250 7.3
84,000 miles
SOLD
bwillis2003 is offline
post #3 of 21 Old 10-13-2010, 09:49 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
The Coolant filter needs to be on a bypass system, if you put it directly inline on the heater hose, and the filter becomes clogged, you will not be getting coolant returned to the motor and may cause overheating.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #4 of 21 Old 10-14-2010, 12:00 AM
It will work untill it quits working
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #5 of 21 Old 10-14-2010, 02:39 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
As long as you hook it to a "T" in your heater line it will work fine. You will just have to source the hose, fittings (those really aren't what you want to use, with top entry you need 90* fittings) shut off valves, and fab a bracket to mount it on. If you are feeling spunky, go for it. There is nothing wrong with your idea except just putting it in your heater line. As long as you hook it up in bypass you will be fine.
Most people that have done this have found that when all is said and done looking at the time spend to do it this way didn't save them any money and if they had to do it over again would just buy a kit.
But hey, yes you can build your own.
RIP Mitch
the Org crew
PGreenSVT is offline
post #6 of 21 Old 10-14-2010, 03:41 AM
Retired Soldier!
MSGDAVE's Avatar
After buying fittings,hoses and filter head from NAPA, i spent about 80 bucks to put my filter in.
love my 6.0
2004 F350 CCLB FX4 Lariat
2.5 pro comp leveling lift
coolant filter
manual hubs
k&n air filter
studs and gaskets
egr delete
line-x
MSGDAVE is offline
post #7 of 21 Old 10-14-2010, 05:39 AM
PGreenSVT's Avatar
Does your install include shut off valves for when you change the filter?
RIP Mitch
the Org crew
post #8 of 21 Old 10-14-2010, 06:15 AM
Retired Soldier!
MSGDAVE's Avatar
Yes,
I put them in so I can close them to change my filter. I bought them at Menards, and they are made of brass.
love my 6.0
coolant filter
manual hubs
k&n air filter
studs and gaskets
egr delete
line-x
MSGDAVE is offline
post #9 of 21 Old 10-14-2010, 06:27 AM
Retired Soldier!
MSGDAVE's Avatar
PGREEN,
I want to know more about vegistroke, do you have a site to go to for more information on it?
love my 6.0
coolant filter
manual hubs
k&n air filter
studs and gaskets
egr delete
line-x
MSGDAVE is offline
post #10 of 21 Old 10-14-2010, 06:38 AM
azkcr's Avatar
Quoted: 3 Post(s)
For the time you're going to spend on getting all the parts together, might as well buy it from someone that has it in one package. (And the housings look better)
I'm all for saving $$ but when it comes to my truck, it gets the best or nothing.
I'm not gunna skimp on something to save a few.
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
