egr valve removal - Ford Powerstroke Diesel Forum
Old 10-13-2010, 08:19 AM
egr valve removal
Is there a way to remove a egr valve or do you need a special tool to do it?
Old 10-13-2010, 09:23 AM
Remove the 2 bolts turn it so the 2 bolt holes are easy to get to run some wire around them with a long loop then use a bar coming off the top of the alternator and pull up
Here is the cleaning page
Diesel Technician Society
You will need new o-rings, it is best to get new
2 stroker
Old 10-13-2010, 02:57 PM
^^^^^And he means "pull up" !!!!
Old 10-13-2010, 04:38 PM
I tried that method some time back, mine was really stuck. I needed a 150 ton overhead crane to lift it out of the intake manifold. I never did get it out.
Old 10-13-2010, 04:46 PM
:O wow!! over head crane!!
Old 10-14-2010, 05:31 AM
I used a come a long attached to the garage ceiling. That little sucker was really in there
Old 10-14-2010, 05:40 AM
PROUD AMERICAN!!!
Feedback Score: 5 reviews
Good lord, you needed a come a long to pull the EGR valve?!!????
Mine came out with just a lil persuasion with a flat head screw driver.
Old 10-14-2010, 08:32 AM
I simply wiggled it loose, used a ladies foot prybar on both sides, popped right out, you shouldn't need a come-a-long or overhead crane! LOL
