Best Price on ARP Studs...and some advice. - Ford Powerstroke Diesel Forum
post #1 of 18 Old 10-13-2010, 04:49 AM Thread Starter
Main question- Where can I find the best price on ARP studs...and get them pretty quick?
04 F350 SRW-Have had issues with surging, dying at idle, puking/losing coolant...etc. since day 1 with this truck(6 months ago). Bought on a Saturday and was at the local dealer that Monday. So far they have replaced FICM, ICP, EGR Valve, BP sensor, some valve related to turbo, and cleaned the Turbo...same problem starts 100 miles or so later after getting it back each time(4 seperate). Finally took it to another dealer which called yesterday saying the headgaskets are blown. Funny, exactly what the local dealer said WASN'T the problem. I asked every time and they said I would just have to keep an eye on the coolant but the other issues weren't related to the head gaskets being blown. Had to give them permission to check EGR Cooler, Oil Cooler, and Turbo to find the causes before warrany(Easy Care/Motor Trend) would decide if they will cover. Warranty actually expired this past weekend but the truck was there and claim # issued before expiration date...still probably going to be fun. Turbo was just cleaned but could it have caused blown HG? Thought is was most likely caused by one of the coolers, right?
So...what besides studs and coolant filter would you suggest for someone on a tight budget? Wife has a rope half way around my neck over this truck as it is and she's 7 months prego so it's probably twice as bad as you imagined! Already spent a couple grand and alot of time without truck on crap that most likely wasn't even a problem...warranty didn't cover FICM, BP sensor, ICP, and cleaning the Turbo.
Thanks!!
Casper350 is offline
post #2 of 18 Old 10-13-2010, 05:44 AM Thread Starter
Update-Oil Cooler is clogged. Dealer says that EGR Cooler is ok but usually doesn't last for long. They recommend replacing($534 no labor) but feel confident warranty won't replace even IF they do cover the other.
Had to give authorization for them to check the cause now I had to give authorization to pull the heads so the warranty adjuster could see where they blew. $2200 so far if not covered...guess I'm in it to win it now!
Anyone ever dealt with Easy Care on blown HGs? Need someone to ease my mind and say they were covered!!
post #3 of 18 Old 10-13-2010, 06:57 AM
ridiculously_necessary's Avatar
know nothing of easy care. get the gaskets replaced, delete the egr and rebuild the oil cooler. arps are a great idea but from what i understand not necessary if the EGR is gone and oil cooler is fresh. unless you have power adders, then arp it.
after warranty work, stay away from the dealer. in too many cases they do more damage to your truck than fixing. hit an independent diesel shop, find one you can trust.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 18 Old 10-13-2010, 07:12 AM
haters gonna hate 24/7.
blueovalman14's Avatar
I actually have a brand new set of head studs that I bought a year ago but never used and they are for sale if your interested.....
PM if you are!
2012 F-150 CC/SB 4x2 Lariat
2005 F-250 CC/LB 4x4 Lariat (Blue/Tan)- Traded In
2005 F-350 CC LB 4x4 Lariat (DSM/Tan) ---> RIP 7/16/2010 (Stolen)
1995 F-350 F-350 CC LB 4x4 XLT
Originally Posted by craftkr View Post
Maybe Choctaw will let you start the LSP Itty Bitty F1Fitty Daycare Chapter????
blueovalman14 is offline
post #5 of 18 Old 10-13-2010, 04:16 PM
helsel_182's Avatar
Send a message via AIM to helsel_182 Send a message via Skype™ to helsel_182
i need the head studs if you dont want them pm me a price..
helsel_182 is offline
post #6 of 18 Old 10-13-2010, 07:39 PM
headviking's Avatar
Thanks!!
What do you mean Warranty didn't cover? It sure should have.
Wa warranty denied for some reason?
Keep the recepts.
You may have some money coming back.
If your commin, it's over. If your stroken, it's just started.
2007 F250 6.0L PSD Lariat - Dieselsite Coolant Filter - Bilstein Shocks - Blue fuel pressure upgrade spring - Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - HFCM Water Separator Drain Plug Upgrade - ARP studded - Engine Oil (Rotella syth) - Rear Diff. & Front Axle (Royal Purple)
HeadViking
Helpful Links:
headviking is offline
post #7 of 18 Old 10-14-2010, 04:24 AM Thread Starter
Keep the recepts.
Easy Care won't cover FICM(told they denied "electronics") or any part that is damaged due to rust or carbon. The BP sensor and Turbo was "gummed-up" with carbon. I love how they make it seem like EVERYTHING is covered but when you read the disclaimer it pretty much gets them out of anything major. Hopefully this won't be the case with the HGs. This was a "free" 6-month warranty from the dealer. Since it just expired I am looking into Fidelity...dealer has had good results with them covering more than others.
post #8 of 18 Old 10-14-2010, 04:48 AM
taskforcefreddy's Avatar
If your head stud deal falls through, the best place to get ARP's is Browns Diesel (do a search). Can gt them for about $396 plus shipping and they have tghem out the door in a day... very quick.
taskforcefreddy is offline
post #9 of 18 Old 10-14-2010, 06:57 AM Thread Starter
Great...thanks for the info!
post #10 of 18 Old 10-14-2010, 02:31 PM
Gatorstroke 6.0's Avatar
i wouldnt go with a fidelity warranty i would go to a dealer and ask about purchasing from them the ford ESP warranty from what i understand it is the best one out there and has the best coverage. for instance some dealers that i have been to before wont even accept aftermarket warranties because the companies are so hard to deal with getting paid from
2006 F250 Lariat CCSB 4x4 off-road
lifted on 35's (Toyo MT's)
Pure Performance 4 inch 4 link with Bilstein 5100's
SCT livewire with innovative tunes!
Gatorstroke 6.0 is offline
