Best/easiest way to take off grill?? - Ford Powerstroke Diesel Forum
Old 10-12-2010, 10:48 AM
Like the title says, I want to do the zoodad. I just finished up the STC fitting and took out the little top bolts on the grill it looks like it's clipped in on the bottom, i had enough wrenchin for the day so put them back and chilled.
Whats the best way from you experienced zoodad'rs out there, THANKS.
Old 10-12-2010, 11:04 AM
Feedback Score: 7 reviews
4 screws on top like you said. then there are 5 clips at the bottom. they are metal and have a lip that flush with panel. (not the grill) just put the screw driver in between clip and panel and pry. the clips will pop right out. start from left or right. because if you stary in the center it will pop right back in
Old 10-12-2010, 11:16 AM
Cool Thanks
