Which is best oil????? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 10-11-2010, 08:32 AM Thread Starter
Question Which is best oil?????
I have an 05 6.0l and I have all the normal problems. So, after reading tons of threads on how to make things better, I've seen that what oil you put in makes a difference. So then what is the best oil? 10W30 or 15W40 and should I use synthetic? Is there anything else I should add with the oil? Any help would be greatly appretiated.
99Transam is offline
post #2 of 11 Old 10-11-2010, 02:08 PM
bfrank81's Avatar
Yes synthetics is a great choice. As for the type there are a bunch of choices and more opinions than you can shack a stick at. Use the search functions and start reading. Then make your own mind up.
I just changed mine with AMSOIL Series 3000 Synthetic 5W-30 Heavy-Duty Diesel Oil (HDD)
Interesting thread I started.
Brian
bfrank81 is offline
post #3 of 11 Old 10-11-2010, 02:41 PM
I use Schaeffer's fully synthetic motor oil, can't believe how smooth the engine runs.
Schaeffer Oil 3.0 | Industrial Lubricants | Diesel Fuel Additive | Synthetic Motor Oils
Leer Canopy
Line-X Bedliner
DieselSite Coolant Filter
Amsoil By Pass Oil Filter
Schaeffer's Fully Synthetic 5W-40
MBRP 4" Turbo Back with CAT Delete
Bullet Proof Diesel Oil Cooler & EGR Cooler
SCT TSX Tow Tune + 50 H.P.
Pyrometer
MountainMan is offline
post #4 of 11 Old 10-11-2010, 03:31 PM
Dirtleg
05strokinfx4's Avatar
Valvoline premium blue extreme, rotela synthetic or mobile 1. fuc amsoil there stuff is over rated why pay more if u still have to change it at the same interval as the rest.
08 f250 king ranch 4x4 innovative 3.03 tuned,5" straight pipe,fully deleted, leveled on 35's, 20x10 -12, cac pipe,diesel site coolant filter
sold 05 xlt f250 6.0l fx4 reg cab black 6" lift studded and deleted, king ranch seats
05strokinfx4 is offline
post #5 of 11 Old 10-11-2010, 07:54 PM
astroinhouston's Avatar
I am facing the same decision as I just got my truck a few weeks ago. Came across this website. Definitely helps direct someone to pick the proper weight with some recommendations for each weight. This isn't a sales site, just info and analysis.
Bob Is The Oil Guy
astroinhouston is offline
post #6 of 11 Old 10-11-2010, 08:10 PM
dieselpower65's Avatar
ive been using motorcraft 15w40 whats everyones opinion on that oil?
dieselpower65 is offline
post #7 of 11 Old 10-11-2010, 10:00 PM
I started out with MotorCraft 15w40 and switched at 20k when i installed the Amsoil by-pass system and started useing Amsoil 15w40 just a few $$$$ more but i think it is well worth it because the injectors run in oil and they like clean oil. The Ford filter cleans to 20 microns and the by-pass cleans down to 2 microns
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #8 of 11 Old 10-12-2010, 04:38 AM Thread Starter
Where is the best place to buy oil? I've checked local auto parts stores and walmart but there is a slim selection? is there a cheaper place online to order it?
post #9 of 11 Old 10-12-2010, 05:15 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
A lot of folks have been raving about the new Rotella T5 10w30. It available at Wally World at a reg. price of about $16/gal.
I prefer Amsoil myself and buy it online.
RIP Mitch
the Org crew
PGreenSVT is offline
post #10 of 11 Old 10-12-2010, 07:54 AM
hazard's Avatar
Valvoline premium blue extreme 5w-40 full syn gets my vote
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
