Stock fuel pump or airdogII?
im having a problem with my airdogII that when i get to 1/4 tank i loose fuel pressure,pretty much from the fuel sloshing around in the tank..i cant just always plan on never running my truck that low on fuel it needs to be fixed.
or do you guys think mabye the pickup broke off in the tank n thats whats causing this problem? so i was thinking about putting my stock pump back on. but i want my fuel pressure gauge hooked up. im curious if anyone knows where i would tap into to read my fuel pressure?? |
The test port on the fuel bowl on top of the engine.
you dont happen to have a picture of the test port do you? cause i dont see on mine where it would go.
Add a fuel sump. Call Truck Source Diesel.....Index
any idea about how much they run before i call?
My truck may have developed the same issue. It has never done that before but as I was driving it home it was loosing fuel pressure. I installed the regulator update kit and cranked the regulator up on the ADII to no avail. I will fill it up when I get home and see what happens.
Interesting ...well let me know..right now I have 3/4 tank n the truck runs fine...how low was your fuel when your truck started to have this problem.?
I'll have to check when I get home. I believe I'm under 1/4 tank but need to check.
Try these guys. http://www.hellmannperformance.com/ Their's is $165 and a nice looking piece.
are you running a fuel sump pgreensvt? and thats weird that randomly your truck decides to start having this problem
