07 STC Fitting - Ford Powerstroke Diesel Forum
Old 10-06-2010, 11:32 PM
07 STC Fitting
Did the 07 come standard with the upgraded STC fitting or is this something I have to add?
Old 10-07-2010, 02:03 AM
Good ?
subscribing
Old 10-07-2010, 06:43 AM
The fitting is installed in production engines starting from:
V8 engines: Engine ser# 431736 on 2/9/07.
V6 engines: Engine ser# 431705 on 2/8/07.
These are the dates they started using the upgraded fitting
Old 10-07-2010, 06:47 AM
Send a message via AIM to troid123
very good information to know. Thanks!
Old 10-07-2010, 07:00 AM
I am going to put my new Powermax in soon and was wondering it this is the time to change the STC fitting.
My 07 was picked up in Oct. of 06 so it still has the old fitting.
Where can I get one and how hard are they the replace?
Old 10-07-2010, 07:04 AM
You have to remove Turbo and other things in the way of getting to the back of the engine valley, take the pump cover off, unblot the pump and remove it, swap out the fittings, reinstall as disassembled. here's the part and your welcome fellas
High Pressure Oil Pump (HPOP) Pressure Fitting Upgrade Kit, 2005-2007
Here's the internation part number for this part but i don't know if it comes in a kit like the bulletproof diesel one does, it might possibly just be the fitting and i haven't priced it out to see if it's cheaper through international
The International Part Number is 1879930c91.
Old 10-07-2010, 07:23 AM
Here's the part number for the kit fellas, still don't know if it's cheaper through international though, Here's the ford kit part number too. The part number i listed above is just for the fitting, not the kit. use the number below for the kit
International Part Number - 1873821C91
Ford Part Number - 4C3Z-9B246-A
Old 10-07-2010, 08:01 AM
OK thanks for all the info.
Old 10-07-2010, 08:02 AM
Not a problem
Old 10-07-2010, 01:22 PM
i was under the understanding the 07 model year the updated fitting was used.
the dates posted above tell me that no production superduty came with the updated fitting, the 07 model year was a very short run because of the early release of the 6.4 08.
the 07 model year trucks were built before the end of october 06.
