Extended Capacity Differential Cover - Ford Powerstroke Diesel Forum
Old 10-06-2010, 05:32 PM
So I'm about due to change my differential oil and am considering changing out the stock differential cover on my '04' 2WD F250 to an aluminum alloy extended capacity cover while I'm at it. The one I've heard about is the Mag-Hytec, which appears to be a premium cover-- at least it's price suggests it is. Would appreciate feedback from ya'll with experience and any alternate covers that may work just as well.
Old 10-06-2010, 07:10 PM
Dont have one on my ford yet however had one on my chevy. If you like the idea of adding fluid capacity to your diffs, and the fact there is a drain plug and a dip stick then go mag hytech. I will be putting one on the front, rear and trans when the $$$$ allows.
Old 10-07-2010, 07:57 AM
Feedback Score: 5 reviews
Just get the '08 up cover..
Old 10-07-2010, 03:23 PM
I agree! They are like $50
Old 10-07-2010, 04:14 PM
Mag-tec is over priced. Get the '08 rear diff cover.
Old 10-07-2010, 04:15 PM
why do u get an 08? do they hold more fluid??? is that for front and rear or what???
Old 10-07-2010, 04:16 PM
Where did I see the 08 diff cover that had a drain plug?
Old 10-07-2010, 04:17 PM
Rear only and it saves you like $200. Simple solution and keeps money for other mods.
Old 10-07-2010, 04:23 PM
does it have a drain plug???
Old 10-07-2010, 04:26 PM
It does not have a drain plug.
