High Idle Mod question - Ford Powerstroke Diesel Forum
Old 10-06-2010, 01:46 PM
So, i read a few posts on the high idle mod, and decided to do it. Problem is, mine does not work. I have an 04 F350 KR Dually FYI. I found the White/Blue wire on the right side of the driver area, and i also found the LB/Y wire on the left side behind the fuse box. Extended the wires, connected to a switch, and NOTHING! Just wondering if anyone else has done this on an 04, and maybe a different color wire was used on the left side behind the fuse box. Thanks!
Also, if anyone knows of a good write up on turbo cleaning, a link would be greatly apprecriated. I will be doing mine this coming weekend. Boost seems to top out at about 22psi, used to get 25-30psi out of it. Sounds like vanes starting to stick. Any help would be great, thanks!
Old 10-06-2010, 02:00 PM
I did mine just as listed in this link:
High Idle Mod
I put mine on a switch with an LED. Do you have a manual tranny?
Old 10-06-2010, 02:06 PM
No i have an auto... That is the exact same post that i used to assist with mine. Found both of those wires, added wire to both, 1 wire to 1 side of the switch, other on the other side. I have nothing. Does the ebrake or anything have to be on??? Does the switch need to be in the on or off position before starting? Just looking for maybe something stupid im overlooking.
Old 10-06-2010, 02:10 PM
i know the ebrake needs to be on, but im not sure if it works on truck without a pto
i too am looking to do this high idle mod but in the thread they mention something about a pto and i have the torqueshift auto tranny w/o the pto
This is a little slow, but has a lot of info for cleaning your turbo:
Turbo manual
did mine last weekend and it worked...
Old 10-06-2010, 02:13 PM
My e-brake does not have to be on. touch the wires together and see if it ramps up. It doesn't have to be already on before you start the motor. The motor does though! I'm just kidding ok!?
Old 10-06-2010, 02:15 PM
Is it a lighted switch?
Old 10-06-2010, 02:18 PM
amdriventoliv- Ha, if it was later in the evening and i had been drinking more, that "motor on" comment may have helped! ha, lol
It is just a basic black toggle switch. 2 posts. NEW, but had it laying in the garage still in the box. If i can get this to work, i am going to mount with a different switch once i find one i like
Old 10-06-2010, 02:33 PM
Are you saying I would have needed to "duck and cover?"
When I was doing mine, I tested them together without the switch. Gutsy? maybe, but it worked. Then to the switch they went. My challenge was I had never wired a lighted switch before. 3 posts instead of 2.
This is where I mounted my extra switches.
