F250 6.0L died - Ford Powerstroke Diesel Forum
post #1 of 8 Old 10-05-2010, 06:14 PM Thread Starter
Standman's Avatar
F250 6.0L died
03' 6.0 lost power going down the high way then died at a stop sign.
I have the AE scanner..
P2287 Injector pressure control circuit intermittent
p2290 injector control pressure too low
p2291 injector control pressure too low cranking
p2614
p2617
HPOP died??
03 F-250 FX4 6.0
Zoodad mod
Banks Bullet
Banks intercooler
2.5 lift in front
Standman is offline
post #2 of 8 Old 10-06-2010, 06:22 AM
well look at 2287 first its a circuit code and possibly could cause the rest
ASE Master Certified Technician
04 Powerstroke lovin it
thenubsterman is offline
post #3 of 8 Old 10-06-2010, 09:58 AM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
Yup. Could be a problem with the ICP or the harness rubbing a wire bare.
RIP Mitch
the Org crew
PGreenSVT is offline
post #4 of 8 Old 10-07-2010, 04:36 PM Thread Starter
Standman's Avatar
Where on the harness do I look? I have the harness loose.. there was oil on the conector to the ICP.
anyone know of a common place where the wires rubbing
03 F-250 FX4 6.0
Zoodad mod
Banks Bullet
Banks intercooler
2.5 lift in front
Standman is offline
post #5 of 8 Old 10-07-2010, 07:00 PM
PGreenSVT's Avatar
AE should be able to monitor the ICP voltage while cranking and running. I'd clean the connector and plug up good and plug it back in and do the above. I missed that you had AE first time around.
RIP Mitch
the Org crew
post #6 of 8 Old 10-07-2010, 07:10 PM Thread Starter
Standman's Avatar
Thanks!! yea it does, I didnt think of that!
03 F-250 FX4 6.0
Zoodad mod
Banks Bullet
Banks intercooler
2.5 lift in front
Standman is offline
post #7 of 8 Old 10-07-2010, 08:30 PM
My Dream's Avatar
Mine did exactly as you describe when my wife was driving it. lost power on the freeway, took the nearest exit then died at the light, got it to start back up but it was very rough, then it was hit and miss as to wether it would start or not.took it to the dealer and they replaced all 4 injectors on the driver side. Truck runs great now.
James
My Dream is offline
post #8 of 8 Old 10-18-2010, 05:45 AM Thread Starter
Standman's Avatar
update
I fix the truck!!!
I never found a wiring problem!! I did see a difirents in the connectors with the harness repair kit for the ICP connector.
I replaced the
ICP
IPR
HPOP
Turbo oil return tube
Couldnt find an oil leak on my HPOP, but my HPOP oil resivor did drain down some over night. The shaft seal was spunggy and lose.
the truck started right up and will start on level ground!!
Thanks to all that helped!!!
03 F-250 FX4 6.0
Zoodad mod
Banks Bullet
Banks intercooler
2.5 lift in front
Standman is offline
