should have known better..... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-05-2010, 10:23 AM Thread Starter
BennyLumpkin's Avatar
Send a message via AIM to BennyLumpkin
Ok so I havent owned my 6.0 for more than 2 weeks and I should have known better....should have kept that 7.3....last week it would cut out throttle....just here and there....yesterday it did it and threw a check engine light....today I was on my way to the dealership I bought it at(used truck warranty) and it died....shut clear off....it was cutting out the whole way here and as I came off the highway exit it shut down....finally it did fire and right before it did it threw a TBC Fault.....whats going on with this thing seems kinda lazy, and the throttle kept giving out.....Im not too happy at the moment if you cant tell....any idea?
The New Toy....06 F350SD CC Long Bed Dually, 6.0, Torqueshift, 4x4, 4.30 Limited Slip, Lariat, Edge Insight, SCT SF3 w/Innovative, S&B Cold Air, Zoodad Mod, 4 inch MBRP downpipe to 5 inch exhaust, Kenwood Flip up DVD w/nav and Sirius, Oil Cooler Rebuild, Sinister, CAT ELC, Extang Blackmax....more mods to come very soon
New Workhorse 2011 F450 V10 4x4 w/ Reading Classic II work body, 19.5's with SIMS, Boss 9'2" Poly VXT plow, XL badgeing with all XLT options but with a rubber floor.
BennyLumpkin is offline
post #2 of 9 Old 10-05-2010, 10:41 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
High pressure oil system problem.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #3 of 9 Old 10-05-2010, 11:10 AM Thread Starter
oh great.....
post #4 of 9 Old 10-05-2010, 11:17 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 24 Post(s)
Feedback Score: 4 reviews
Dirty Fuel filters, FICM. Being an 06, it could be the STC fitting, or the dummy plugs. Ford has new updated parts to replace these though, and hopefully that warranty you have will cover them
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #5 of 9 Old 10-05-2010, 11:21 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
Needs to be scanned
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #6 of 9 Old 10-05-2010, 11:37 AM Thread Starter
Im sitting at the dealership right now.....waiting to hear the news...I had it scheduled for an axle seal that was bad when I got it, and the window washer motor wouldnt work.....those are easy fixes....Im just worried about the CEL and what is behind it.
post #7 of 9 Old 10-05-2010, 01:52 PM
RZR007's Avatar
I wouldn't lose faith in the truck. This might be the only problem you'll ever have....
Having said that... I'm glad you have a warranty.
2006 F-250 XLT Crew Cab
Zoodad mod
BB mod
Coolant Filter
Cat Delete
MBRP 4" Turbo back
SCT
Fuel, Trans, Pyro, and Boost Gauges
2.5" leveling kit
Upgraded banjo bolts
Kenwood w back up cam
Alot of prayer
RZR007 is offline
post #8 of 9 Old 10-05-2010, 02:02 PM
Chapter Director
cubalz's Avatar
Sounds like bad luck. At least you have a warranty. Some haven't been so lucky.
2004 F350 6.0L Power Stroke Diesel
4.5" Lift
37 x 13.50 x 16 Pro Comp Extreme AT Tires
Mickey Thompson Classic II Rims
Power Tow Mirrors
Ranch Hand Front Bumper
Bully Dog RFI Intake
Bully Dog Outlook/Triple Dog Power Pup
ARP Studs
Blocked Off EGR Cooler
5" Exhaust Tip
Low Profile Toolbox
Prodigy P2 Brake Controller
Kenwood In Dash DVD Double Din Radio
HFCM Water Separator Drain Plug
Dieselsite Coolant Filter Kit
cubalz is offline
post #9 of 9 Old 10-05-2010, 02:53 PM Thread Starter
well I checked out the Oasis while I was sitting in the waiting room....the truck has NEVER had any repairs reported on the Oasis report in all 157,000 miles....what its doing is dumping fuel to the crankcase....guy is pretty sure its a stuck injector....the shutting down he said was caused by the fuel thinning the engine oil...it would cause a loss of pressure to drive the injectors which would make it shut down...the TBC fault he said is a trailer brake fault....if you crank a 6.0 long enough it throws the fault for some reason....he's seen them do it before....so they gave me my old truck back as a loaner, mine should be fixed by the end of the week.
