problems with a mod, need advice!
I have a 2007 F-250. i purchased a Dr.performance power module (Gen II). its just a plug in not a programmer. it plugs directly into the ICP sensor. it fools the trucks sensor and increases the fuel pressure. since i have put this mod on (about a month ago) i have started experiencing some starting issues. The truck cranks strong but wont fire up. the other problem i experienced one time and that was when i came to a rolling stop the truck revved up a little and lurched forward some while i was on the brake. when i called the company they told me that the lurching forward was possibly caused by a cracked injector nozzle. i can understand that but it doesnt explain the cranking but no start condition. i have tested the batteries and both are putting out 13v but i have not conducted a load test. any advice or ideas to help me when i deal with the dealership would help thanks! the website to the company is www.drperformance.com
Any other mods?
I suggest an SCT ![]() The starting issue could be the STC fitting, or dummy plugs. It could be more than that too. Get to a dealer and have them check for codes. That would be where I would start |
dicth that drperformance and go with a sct, if u have to rig something connecting ur icp sensor that would cause the no start, and the lunge could be alot of things, mine turned out to be a an ipr valve
There's your problem your screwing with the setting making it fool itself, get it out.
Go back to stock, then get an SCT...
what they said ditch that crap and get an sct with custom tunes!
