I currently have a cracked y pipe or leaking exhaust connection near the turbo. I can hear hissing and smell the exhaust. Still need to hunt it down, but was planning on putting a egr delete pipe in so figured I would just replace the y pipe since they usually crack anyway.
Has anyone installed one of these or something like this?
If so what other parts are needed to complete this project? How hard
is it on a scale of 1-10? I just replaced a head on my 1994 f-150 4x4 and that was about a 6-7 for me. How long will it take?
I still have the egr intact, but with the new pipe it won't be connected to the exhaust. So do I just cap it off? If so how or is there a part I can buy to do this?
Last, Are there any other y pipe out there I should be looking at? Trying keep the cost reasonable and the truck is stock.
I just put in that Y pipe full solid, it is an excellent product and they gave me great service and quick shipping. Definately get this one over the stock junk!
I didnt do my EGR delete so cant tell you much on that, either way you will be taking the turbo out so get a gasket & O ring kit for it, I cleaned my turbo as well while it was out pretty easy to do.
If you have an '05 up (sorry forgot what you had) you may want to consider getting the kit to upgrade the STC fitting on the HPOP, I have less than 50mi since Y pipe replacement and I have HPOP leak :doh: so one of these weekends back in I go :tard:
The mechanic that put my EGR delete in used a new coolant pipe (specially made with fittings) tossed the EGR cooler and blocked the outlet on the Y Pipe.
I would say the Y pipe job would take about a day, took me longer cause I clean stuff and paint crap, a little OCD I guess.
I sent a PM to another member on the process I did for the Y pipe if you want I could forward it to you check out.:thumb:
I used the liberator EGR delete and am very happy with it. I think the quality is better than some of the other kits out there. It will come with pretty decent directions and I've found some good write ups searching here.
Time wise it probably took me a good 10 hours but I was able to work on it in stages since my truck isn't a daily driver. One piece of advice I was given was to replace the oil cooler since you'll have everything apart anyway. Seemed like a good idea so I did it and added a coolant bypass filter as well.
Scale of 1-10 I'd say 6-7, it's mostly just the process of taking everything off the top of the engine then putting it back on. You might want to consider new intake gaskets too, depending on the condition of yours.
I wasn't planning and completely removing the egr just blocking it off, so I doesn't receive any exhaust. My understanding is the egr should last quite a while if it doesn't melt down due to exhaust gases.
PMd you the process, sorry for the delay busy with work and stuff lately.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
