6.0/6.7 Conversion? Has Anyone Tried it Yet?
Does anyone know if you can convert a 6.0 into a 6.7? It seems to me that if you could buy a crate 6.7 from Ford the conversion would be rather straight forward. Any ideas???? Techs out there, what are your thoughts?
I think the 6.7 is a lot bigger than the 6.0. not sure how the trans would do. a crate 6.7 is near imossible to get and more expensive than you can imagine
Would need the PCM wire harness transmission and a bunch of other stuff to do it. Instrument cluster from a 6.7 truck as well
might as well get a cummins. Cheaper and proven.
I will say this though, i rode in a new ford the other day and good lord that thing is awesome.
id say put a cummins in there way cheaper and easier.
look for a wrecked 6.7!
your going to need alot of $$$$ too there is a guy that does excursion conversions to 08s im sure he could slap a 06 front end on a 6.7 for you
I think I read somwhere that when Ford went to the 6.4, that they re-did the front clip to accomodate a bigger radiator or intercooler or maybe both. So you would need to look into if it was re-designed again for the 6.7 .
Yes, they redesigned to fit the 6.7. If you remember the test mules the 6.7 didn't fit in the 6.4 engine bay. That doesn't mean an enterprising individual couldn't make it fit but it isn't a simple bolt in.
