stock egt temp - Ford Powerstroke Diesel Forum
Old 09-29-2010, 06:32 PM
stock egt temp
Hey guys Im thinking i have a problem with the truck. I was woundering what your egt temp is when you running stock? Mine last night was about 1000 but i wasnt even hard on it at all. I did just put some new gauges is so i wounder if it could be the gauge to but it all so seems to run a little rough when its could.
Thanks Jeff
Old 09-29-2010, 06:38 PM
Feedback Score: 3 reviews
Do you have a boost gauge? If your low on boost with high EGT's, look for torn IC boots. A egt valve stuck open will also cause high EGT's and run rough.
Old 09-29-2010, 07:08 PM
Ya I have a boost gauge and i think it was about 20 psi while i was on it. i will pull the egr valve tomorrow and look at it.
Thanks Jeff
Old 09-29-2010, 07:15 PM
Here is a link for normal stock and tuned temp readings:
Recommended readings - Temperature and Pressure - Ford Truck Enthusiasts Forums
Old 09-30-2010, 03:33 AM
In normal driving I'm usually 600-800 degrees. If I get on it for a bit I may break 1000. This is pre-turbo, and I'm stock.
Old 09-30-2010, 04:01 AM
Thanks guy so im right in there. I was scared it was to hot.
Thanks again Jeff
Old 09-30-2010, 07:12 AM
Good info
Old 09-30-2010, 08:10 AM
what gauges do you use to check all that
Old 09-30-2010, 08:19 AM
Well, right now I use Scangauge II, some use Edge Insight. The only things the Scangauge doesn't read, is EGT's, Fuel pressure, Oil pressure. The boost part of the Scangauge is doing weird things on mine, but it reads all things the PCM reads , which is through the OBD port.
I will be looking at EGT,Fuel, OIl pressures on manual gauges soon.
P.S. Edge Insight can be purchased with a additional probe for EGT's.
Scanguage II =$160
Edge Insight w/probe=around $350, w/o probe $280 ? Not sure.
Old 09-30-2010, 08:26 AM
Or you can do this: (this is not my truck, this was posted by robts )
