5+ gallons of oil in my motor - Ford Powerstroke Diesel Forum
Old 09-29-2010, 01:23 PM
so I am still working on my egr delete and got the oil cooler out and the valley under it is full of oil. How do you get the oil out of therte or is it supposed to drain on its own?
I then drained the oil out of the pan put a 5 gallon bucket under it filled that one up and probably about a gallon in another. what causes them to be over full like that or could it be the guy who owned it before over filled it
Old 09-29-2010, 02:17 PM
There is a screen under the oil cooler. If that is mostly plugged I could see the oil not draining well. This screen should be replaced so reach through the oil and pull it out. As for oil, these take the better part of 15L's of oil. I am not sure what that is in gal. but it sounds like you may have been over filled.
Old 09-29-2010, 02:20 PM
I have the screen out already, valley is still full
Old 09-29-2010, 02:27 PM
Almostdunfukinwidit
its 15 quarts
Old 09-29-2010, 02:29 PM
should be 3.5 gallons, figure something out
damn key boad, i would figure something out towards where the extra oil is coming from. As simple as the guy before you over filling? I dont know if it would run with an extra 3 gallons of oil in it.
Old 09-29-2010, 02:30 PM
Almostdunfukinwidit
What you are seeing is most likely oil that was trapped in the HPOS
Old 09-29-2010, 02:36 PM
say no to rolling coal
So you're saying you drained 6 gallons of oil out of the pan? Better check to make sure there's not a couple gallons of fuel in that oil.....
Old 09-29-2010, 02:38 PM
Almostdunfukinwidit
If thats the case yes definately.
I took it as he drained the pan pulled the oil cooler apart removed the HPOP screen and has a bunch of oil in the valley now
so can I just dip it out with a cup or something and be alright. I am just curious about the oil in the valley because all the pics I have seen it is empty
