down pipe
so I am trying to do my egr delete and I am having a problem getting the down pipe out. What is the easiest way to get it out?
Stock DP or A/M?
it is the stock one
You have to cut it or remove the tranny crossmember. You can do a EGR delete without removing it...
I was just thinking it might be easier to get to the back turbo bolt with it out of the way
It's easier if you have a A/M DP...
i had the same problem getting the down pipe out because the exaust insulation made it difficult. i had to cut the exaust pipe at the bottom of the engine. then u have to twist it certain ways and pull down and it should come out
got the bolt out what a pain in A$$ and getting the turbo out was even worse
