CAT ELC
Found a cat dealer here in memphis, tn that sells the cat elc for 11.58 gal,for some reason I thought it would be a lot more, after reading some other post about this coolant,
That is probably the pre-diluted version. The full concentrate is around $30!
u are wright I called back and the rep said it was the 50/50 blend, will this not work over 3gal full strenth and 3gal water ?
using 50/50 is impossible to end up with 50% since theres a gallon or two of old coolant that cant be gotten out...get the concentrate, it works out to the same price
So do I add 3gal of the concentrate then top off with water ? |
I used the 50/50 mix and after several cooling system tests and coolant test strips, my coolant is PERFECT and is actually a hair stronger than what it should be.
You'll be fine. |
![]() now then, if you were at an HONEST 50/50 prior, the laws of physics will not allow you to hit the right mix...unles you have the capability to turn your truck upside down when flushing
![]() another take on this...we are not taking a price difference here (the 50/50 is about 1/2 the price of the concentrate) and buying the concentrate guarantees the 50/50 |
