draining coolant - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-27-2010, 02:32 PM Thread Starter
draining coolant
I had a couple questions about draining the coolant on my 05. I will be doing the bulletproof egr cooler and oil cooler and want to drain the whole system because right now there is oil mixed with coolant. Do I just pull the lower hose and flush it 2-3 times with vc-9, then change the hoses and thermostat after it's flushed the final time or is there anything else? Also what coolant would be best, evans, motorcraft gold coolant? I'm also considering ordering the dieselsite coolant filter kit and installing it after everything else is done. If anyone can help out that would be great, I really need the truck running again.
2005 F-350, 4" mbrp turbo back stainless exhaust, Bilstien shocks, bulletproof diesel egr and oil cooler, dump body
Simoncx is offline
post #2 of 8 Old 09-27-2010, 03:00 PM
Boog's Avatar
Garage
Simon,
Keep reading down this page and probably the next two. There are several threads with really good information on a proper coolant flush, also there is some advice on which type of coolant to go with.
2006 F-250 Lariat CC 4X4
S&B CAI
SINISTER COOLANT FILTER
EDGE CTS MONITOR
PHP 40 ATLAS
LEVELED W/ BILSTEINS
Boog is offline
post #3 of 8 Old 09-27-2010, 03:13 PM Thread Starter
Thank you, found it. I'll try to see who carries Rotella ELC around here because i've never seen it at the auto stores. Also will vc-9 clean out the oil or do I need dishsoap and how much do I add, I dont want to add too much dishsoap and have foam coming out .
Simoncx is offline
post #4 of 8 Old 09-27-2010, 03:18 PM
Boog's Avatar
Garage
Hopefully someone who has used it will chime in here and then we will both know.
S&B CAI
EDGE CTS MONITOR
PHP 40 ATLAS
Boog is offline
post #5 of 8 Old 09-27-2010, 03:50 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
If you have oil in the the coolant, you will need to flush real well with Simple Green before using the vc-9. Get that oil out first the best you can.
Here is a thread on the subject:
removing oil from coolant system - Ford Truck Enthusiasts Forums
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #6 of 8 Old 09-27-2010, 04:12 PM Thread Starter
Thanks, that thread helped alot but does it matter which simple green, on there website they have alot of different products.
Simoncx is offline
post #7 of 8 Old 09-27-2010, 04:55 PM
Quoted: 4 Post(s)
Man, I saw a picture of what they use, but can't place the thread. I'll look around.
post #8 of 8 Old 09-27-2010, 05:36 PM
RIP Mitch ! We miss you
PGreenSVT's Avatar
Feedback Score: 3 reviews
I like Greased Lightning instead of Simple Green of oily greasy stuff. Pull the thermostat at the beginning of your flushes so that you can get the coolant etc circulating immediately without the restriction of the thermostat. VC-9 is for rust removal and will not help with the oil. Flush well several times with distilled water and drain the block as well. Then refill with ELC coolant.
RIP Mitch
the Org crew
PGreenSVT is offline
