ScangaugeII readings
Just installed my new scanguage 2 and its a pretty good gauge for the money. These are some of the readings I'm getting after everything is up to normal operating temp. Are these good numbers?
EOT=195 deg. f. ECT=188 deg. f. Trans=147 deg. f. ICP=642 @ Idle, 1200+ @ 60mph, 4000+ gettin' on it
Looks pretty close to what my Edge CTS shows.
Thanks, thats what I was hoping. Just wish there was some way to monitor fuel pressure with this thing. Guess I'm gonna have to install one into my pillar. I can take out the volt meter and replace it with a fuel pressure gauge since I can monitor volts with the scangauge.
Valparaiso ehh? Ever get to Coatsville or Filmore?
Nope. Thats quite abit south of my stompin grounds. I'm sure I've been thru the area a time or two but cant rembember.
When I run my ICP, I also run the IPR at the same time. They seem to work hand in hand.
At idle: IPR=22.5 ICP=585 or a little higher Of course engine is hot when I read these. |
I'll have to check that.
