Going to change out coolant in 03. - Ford Powerstroke Diesel Forum
Old 09-26-2010, 03:47 PM
Planning on running Shell Rotella ELC concentrate 3.5 gallons, and 3.5 gallons of distilled water.
As for the flush, I drain the radiator. Where are the plugs on the back of the block? I think I located one, but it is an allen wrench type bolt, where is the one on the passenger side?
Also, after I drain all the coolant, do I just fill it up with water and run it until the thermostat opens or just leave the drain plugs out and run water through the system with a hose?
Thanks guys.
Old 09-26-2010, 04:20 PM
The other one is above the starter. tough to get to. I would get 2 quarts of VC-9 and get it good and clean.
This link might help. I would pull the T stat. I didn't when I did mine. saves a lot of time:
Coolant Change 101 - Ford Truck Enthusiasts Forums
