Headgaskets went out! - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-25-2010, 05:06 PM Thread Starter
Hey guys,
So about 8,000 miles ago I had a dealership back where I used to live install new headgaskets and ARP studs. Truck was running great until about a few weeks ago, when I noticed my coolant had been puking every once in awhile. Was only using my Tow tune and it still puked. I had to get it looked at so I brought it in to the dealership down here in Sarasota and they started doing some research and tearing down the truck. After about a week of having it they called me to say the headgaskets had gone out. When they pressure tested the coolant system they said on full throttle it would build up to almost 30psi. Come to find out the reason they said they failed with the ARP studs is that the last dealership didnt clean the heads off very well and still had the original ford gaskets silicone all over. I sent pictures to my old dealership and I have insisted that they pay for this since they screwed up. Now I need another set of gaskets. The heads have a few hot spots where the coolant was seeping out in places. I'm furious that someone didnt take the time to do this correctly. What should I make sure this dealership does while the engine is apart again? I'm definitely going to check things before he puts it back together, and probably have the heads sent off to be checked. Here are just a few picks of what the heads looked like. What do you guys think? thanks
Name:	LeBlanc truck 001.jpg
ID:	18074   Click image for larger version
Name:	LeBlanc truck 009.jpg
ID:	18075   Click image for larger version
Name:	LeBlanc truck 012.jpg
Trent
2006 F-250. 5" lift, ICON 2.0 shocks, 315/70/17 Goodyear Duratracs, 17" Weld Wheels, MagHytec cover, 4" Banks Exhaust, AFE Stage 2, Banks High Ram intake, 6000K HID headlights and fog lights, Recon lights,Fumoto Oil Drain , SCT tuned (IDP, Gearhead, Quicktricks), Edge CTS Insight,ARP studs,EGR delete, Powermax turbo w MTW billet wheel, NUC Oil Bypass filter and Dieselsite Coolant Filter,Ford Upgraded Fuel Spring
GAstroker2006 is offline
post #2 of 9 Old 09-25-2010, 05:11 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Make sure this dealer checks the heads for flatness
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 9 Old 09-25-2010, 05:12 PM
SickStroke6.0's Avatar
Feedback Score: 9 reviews
Just get the heads machined for flatness, and slap her back together with ARP studs and an EGR delete. Should be good to go.
Blake
2013 F-150 CCSB Oxford White FX4 EcoBoost
Loaded with every option...
2008 F-250 CCSB Dark Copper King Ranch 6.4L FX4
4" MBRP Exhaust w/ Muffler (DPF/DOC Delete), Modded Stock Intake, H&S XRT Pro
SickStroke6.0 is offline
post #4 of 9 Old 09-25-2010, 08:42 PM
smokersteve's Avatar
Quoted: 20 Post(s)
That sucks!!! Now you got all the reason to get it done right at their expense because it was their fault!!!!!
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #5 of 9 Old 09-26-2010, 05:34 AM
Geoff941's Avatar
Make sure Dave works on your truck.
The reason I need a Powerstroke
2003 6.0 crew cab DRW
Edge Insight
EGR delete
DFuser coolant filter and EC-1 fluid
Need a BIGGER boat to tow
Geoff941 is offline
post #6 of 9 Old 09-26-2010, 10:11 PM
raisemhigh's Avatar
Any maintenance done my the dealer has a 12yr/12mo warranty
SOLD: 2004 F250 6.0L, 8" on 38s, SCT, intake, exhaust, studded and gutted
raisemhigh is offline
post #7 of 9 Old 09-27-2010, 06:04 AM
k2davis1's Avatar
I would make a bet that lack of cleaning isn't the root cause of your problem, flatness is the culprit. Must must must get them machined not just check with a straight edge. good luck
2008 F-350 Crew Lariat FX4
6" RCX lift W/37" Falkan A/T
24" Fuel Hostage
5" Flo-Pro Straight
H&S Mini Maxx
S&B CAI
k2davis1 is offline
post #8 of 9 Old 09-27-2010, 07:05 AM
Abrannan19's Avatar
Feedback Score: 5 reviews
check cylinder walls too for cracks...
Adam Brannan
First Coast Diesel Performance
Abrannan19 is offline
post #9 of 9 Old 09-27-2010, 10:23 AM
DerwoodF350's Avatar
I know its a minor thing but check the Y pipes for cracks in the expansion joints, wayy easier to change now than 3 months later like I did.
2006 Fthreefidy FX4 Lariat, ARP studs, EGR delete, 4" TB BD X-hale exhaust(JUNK), RCD 2.5" level kit w/Bilsteins, Nitto Terra Grapplers, SCT Livewire, Liberator Y pipe, Dieselsites Coolant filter & Delo ELC, Zoodad mod, Swamps HOT FICM, Matts SRL++ & tow tunes
, CCV Mod, CompuStar 2way alarm/remote start
To do list: fluids changed out to synthetic,HID's, .
DerwoodF350 is offline
