Whine When Cold - Ford Powerstroke Diesel Forum
Old 09-25-2010, 10:54 AM
Feedback Score: 9 reviews
Whine When Cold
Okay, in 1-2 gear, my truck will make this weird whining noise, and I can't figure out what it is. I thought it was the transmission, but I just got it flushed, and no change. Motor was just torn down a bit to replace a leaking pipe off the turbo, still no change.
This is the only two things I can think of.
-I don't have the updated degas cap
-And I didn't put an O-Ring/Gasket on my EGR Valve Blocker Plate. I have the RCD EGR Delete, does anyone still have the instructions, and whether or not it requires an O-Ring? It had a ring inside it, so I guess it may have fooled me.
Here's the ring I'm talking about:
Mods in sig.
Old 09-25-2010, 10:55 AM
Also, I can hear it as well when it's warm, but not as noticeable.
Old 09-25-2010, 06:20 PM
Old 09-25-2010, 06:41 PM
check your power steering fluid
Old 09-25-2010, 06:50 PM
How do I check the power steering fluid? And would that make a noise without turning the wheels?
Old 10-05-2010, 12:55 PM
Can anyone else shed some light? I really don't want to take this to the dealer for this...
Old 10-05-2010, 01:26 PM
Mine makes a goofy turbo low pitched howl sometimes when cold and warm, my buddies 05 does it to, its fine mine has done it for a long time as well as his I have no problems with my truck or his. Probably not what you wanted to hear but its all I can come up with lol sorry man
Eta- you need that o ring on the egr valve blocker plate otherwise you have no positive seal. Pull it off and install that o ring its there for a reason. Otherwise you have a boost leak
Old 10-05-2010, 01:39 PM
Really? I assumed since it had a ring underneath it that it would be aight. But I think that may be my problem. The only problem is, when installing the blocker plate I stripped out the threads in on one side. So I swapped it with a bolt from the intake elbow (which is a little longer) and put some Loc-Tite on it, hoping it wold stay, and it sealed pretty good. But I guess I'll have to take it off again, and this time I'll just clean my EGR valve and stick it back in.
Old 10-10-2010, 08:57 AM
Update, put the EGR valve back in with new gaskets and O-rings, and also got the new updated degas bottle. Still whines.
