Putting a 2.5" Icon lift on my truck (PIC)
Been trolling around all the leveling threads and have decided to just level my truck rather than lift it.
Icon (or Donahoe Racing?) seems to be pretty popular around here, so that's what I'm gonna pick. Eventually want to put 35 Toyo MT's on the factory rims. Any thoughts? Should I upgrade the rear shocks like it suggests? Here is my truck:
I put the RCD kit in and got all four Bilstiens shocks. Absolutely love it, way better ride. Your spending all that money on snazzy stuff for your front end might as well chip in the extra for the rear, those shocks are gonna be much better than the stockers...
I had a bad one in the rear as well, didnt know it till I took it out. My $.02CDN lol BTW nice ride dude! |
I have the exact truck in an 07. Same color scheme as well. Be nice to see your end result after you level it..
I did a Google search for RCD leveling kit but couldn't find any retailers for it (for an F-250 anyways). I bet they are similar in price. But I will definitely take your word and get the rear shocks as well.
I'm about two seconds away from ordering and Edge CS too. Haven't had any troubles with my truck yet (55,0000 miles) so it will help me monitor my coolant temp more closely when something bad does happen. |
leveled is the way to go, and the edge cs is pretty much the bomb
Yes, you should get the adjustable trac bar as well. It will shift your axle and cause scrubbing on your front tire. I didn't and scrubbed the outer edge of my front passenger side tire and had to replace it MUCH earlier than I should have.
Here is pic of what I'm talking about:
The panel you circled is all one piece, but the small panel just above with the vents on it will pop off. I actually looped my cord up and put it directly under the steering column zip tied up good -- I thought that worked best.
I had mounted an Insight CS on the pillar, modified a mount so it would fit (I think the wiring is different location from original Insight), but I upgraded to the CTS and there was no way that was going to mount there. Truthfully, I didn't think the unit was held on secure enough with the velcro and it almost seemed to be angled down. I went with the dash pod and am happy with that now. Actually, I have the a-pillar mount still, and it's painted the tan to match my 06 F350. If someone wants it and is willing to cover shipping, let me know. Adam |
Is where I got my kit from. The guy was helpful and shipping was fast. I think the Icon kit is a couple hundred more but it comes with some sweet progressive rate springs which are supposed to be very nice. These kits come with camber shims, a guy here at a front end shop said they dont use them in their kits, but they just use the spacer kits, I drove it for a bit with out them in, truck wandered a bit I didnt like it so put em in and way better, so put them in. Actually come to think of it I think for the F250, you would need to get the F350 blocks for the rear springs and it will bring your 250 up to the 350's height. Are you installing the kit yourself? |
