Changed Coolant Filter for the First Time Today
This morning I changed the coolant filter on my DieselSite filter system. I installed the coolant filter at 26,000 miles and had the Ford dealer do a flush and installed new coolant before installing the filter. I cut the filter in half to see what was inside, needless to say there was alot of crap. Now I am concerned what is lodged in the oil cooler.
So with all that junk do you do another flush this time with VC-9?
What coolant did the dealer put in when they flushed it? |
I'll just keep changing the coolant filter on a regular basis. The Ford dealer installed the Ford Gold coolant at the time of the flush. Upon further research the Ford coolant is what causes issues with silicate fallout. If I was to do it over again I would have installed Evans coolant.
![]() 2 stroker |
I just put the CAT ELC in mine. I'm installing the coolant filter tomorrow.
how many miles u have now op?
Opps. I forgot to mention that.
I now have 31,000 on the odometer; (5,000 miles on the first coolant filter.)
Kind of similar question. When you install and/or change the filter do you risk introducing air bubbles into the coolant system? If yes how do you prevent that?
Its recommended when you first put the coolant filter on you change the first filter after a month, then 3 months then every 6 months
Independent of mileage?
