Transmission Fluid Level Question - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-22-2010, 06:14 PM Thread Starter
Hey guys, sorry for the stupid question but I've searched on here and don't have a factory manual so I was wondering what is the correct procedure for checking the trans fluid level on a 05. I checked it in park on a flat surface with the motor running after driving the truck for about 10-15 minutes of mixed driving. the dipstick read between halfway to full on the cold section of the stick. I assumed at that point it should be reading on the 'hot' section, as I'd think it would be at operating temp after a 10 minute drive??? I went to buy fluid and my Ford dealer told me if it shows on the stick (even in the cold section) to leave it alone but that doesn't seem right to me. I'm leaving on a trip tomorrow and taking the truck so I'd like to get it sorted asap. Thanks, Tyler
70cuda is offline
post #2 of 9 Old 09-22-2010, 06:52 PM
Galaxie's Avatar
That doesnt make sense. Make sure it is correct on the stick.
Colin
59-68Galaxies, Fairlanes
54 Ford Skyliner Glass Top
60 Country Sedan Wagon
87/93 5.0s 347
Buy/Sell/Trade/Service 40s50s60s cars!
06 F350 Dark Stone XLT FX4
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Black Windows/lights
Blue Spring
03 Turbo
Galaxie is offline
post #3 of 9 Old 09-22-2010, 07:22 PM Thread Starter
thats what I figured, so checking in park is fine? How long do you have to drive until it is considered 'hot'?
70cuda is offline
post #4 of 9 Old 09-22-2010, 07:24 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Cold and hot are more like normal and SCALDING. From doing checking trans levels at LEAST 20 times a day for about 8 months now 5 days a week that's what I've realized. If your engine is really hot then check it at hot. If it's just normal warm to hot then it should be lower on the stick.
Ok so maybe not scalding but pretty dang hot. But not cold and hot. Warm and pretty hot.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 9 Old 09-22-2010, 07:25 PM
Galaxie's Avatar
I would run a good ride. I just checked mine after my ride home from work (14 miles)
Colin
87/93 5.0s 347
SCTX3 Custom Tunes
ARP Head Studs
EGR Cooler gone
MBRP Stright Pipe
Edge Insight
20" Harleys 35" AT2
2011 Tailgate
Eaton TrueTrac
2" Leveling
Blue Spring
03 Turbo
Galaxie is offline
post #6 of 9 Old 09-22-2010, 07:30 PM Thread Starter
yeah, my truck wasn't 'scalding' when I checked it (coolish day out, not pulling a trailer or anything, not even really stop and go driving) - so the top end of the cold rating on the dipstick is probably fine do you think?
70cuda is offline
post #7 of 9 Old 09-22-2010, 07:36 PM
jesilvas's Avatar
Quoted: 2 Post(s)
Yea. Check it when you first start it up. On level ground in P. Then it should be right around C
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 9 Old 09-22-2010, 07:38 PM Thread Starter
cool, thanks guys I really didn't want to overfill so this is helpful
70cuda is offline
post #9 of 9 Old 09-22-2010, 07:39 PM
jesilvas's Avatar
Quoted: 2 Post(s)
You can always just drain the pan and then start over from there.
4R100, 2wd
330,000 + miles
jesilvas is offline
